Engine Build Time
Old Feb 3, 2014 | 07:19 PM
  #261
HD Pilot's Avatar
HD Pilot
Did a little work this afternoon, first I pulled the old cams off the cam plate and then removed the HD oil pressure relief valve so I could install the Axtell oil bypass valve. The HD oil bypass piston was a little difficult to remove but a ball end allen wrench had enough contact with the inside of the piston to slide it out.
In the picture you can see the 1/8" punch used to remove the roll pin and the homemade tool I made to push on the spring as I "punched" out the roll pin. I made the tool out of a 3/8" dowel that I cut the middle out to about 1/2" up the dowel using a table saw.
Here is a pic of the old HD oil bypass valve with the Axtell below:
Old Feb 3, 2014 | 07:31 PM
  #262
HD Pilot's Avatar
HD Pilot
Here are the old HD cams on top with the Tman 590s below:
Here is the front view of the 590s installed. Hope it looks good to everybody?
Really had no difficulties, went just like the Fuel Moto and S&S videos. On the front cam you can see the new retaining ring installed. The HD SM tells you to install it with the "sharp edge out" - if you feel the front edge with your finger, it does feel sharper but when I pulled the original ring off I noticed the ring "bulges" out on the side that faces out - so I put the new one in like the original.
Old Feb 3, 2014 | 07:38 PM
  #263
hell hound's Avatar
hell hound
lookin good
Old Feb 3, 2014 | 07:45 PM
  #264
Suede Blue Man's Avatar
Suede Blue Man
Those big fat cam lobes look sweet!
Old Feb 3, 2014 | 08:07 PM
  #265
128auto's Avatar
128auto
Keep up the good work! Looking great
Old Feb 3, 2014 | 08:22 PM
  #266
soft 02's Avatar
soft 02
Originally Posted by alansummrs
Good job! Looks like you got plenty of red loctite behind those thrust washers....
Old Feb 3, 2014 | 08:32 PM
  #267
HD Pilot's Avatar
HD Pilot
Just playing with my Red Line Assembly Lube. Cleaned my tensioner holes and fastener threads and a bit of blue just like you said
Old Feb 3, 2014 | 08:34 PM
  #268
soft 02's Avatar
soft 02
Was kidding of course!
Old Feb 3, 2014 | 09:01 PM
  #269
HD Pilot's Avatar
HD Pilot
Yeah, I knew but I didn't want anybody else wondering , plus it was a good lead in to using assembly lube.
Wont be able to install the plate for awhile, so I wrapped it in a clean T-shirt and stuck it in my closet.
Old Feb 3, 2014 | 09:05 PM
  #270
QC's Avatar
QC
A t-shirt? Really??
You got a problem with using the "show towels" like the rest of us?
