Engine Build Time
Old Jan 17, 2014 | 08:26 AM
soft 02's Avatar
soft 02
I'm on a temporary ban from HTT for a video I posted. I'm pulling my motor today and got my new 107 kit from FM yesterday. I should be running in a week.
Old Jan 17, 2014 | 08:34 AM
HD Pilot's Avatar
HD Pilot
Here is my Parts/Tools list as it stand now. If I need to update it as this build goes forward, I will.
Throttle Body: HPI 55 1.80*,*new HD seals*
Cams: Tman 590 $377 *
Cam Bearings: Torrington B-168 Heartland $17**
Inner Cam Bearing Remove/Install: Heartland*$100 *
Oil Pump alignment screws (2) Heartland*
SE wrenches(3), ACR tool, SE Lifter holders, SE Pushrod tool $167(all*)
Cam Locking Tool $20 Ebay *
Piston Ring expander $8 Auto Store *
3/8" Socket "ball end" Allen long wrench 3/16" *
Cam Spacer Kit: HD 25928-06 *
Exhaust Gaskets: HD SE flat *
Pushrods: 1) S&S Quickee Adjustable Cover kit $182*106-6051 *
Lifters:*S&S Prem High Perf w HL2T 330-0174 $260 *
Headwork:*AMS CNC 1.900 Intake 1.610 or 1.575 stock Exhaust valves, .600 AV&V max lift springs
Feuling Pinion Shaft Run Out Tool $101 #9015 *
Big Bore:*AMS 107" .060 over bore
Compression Tester: OTC 5606 $52 Amazon *
Breather Filter*/tubing/clamps/caps
Tappet Block Centering Screws(rocker boxes) - the oil pump ones should work *
Engine Oil: Dyno for break in 20-50W*(5-30W?)
HD cam and top end gaskets *
Kent Moore Circlip installer EN-46745 $70 Ebay *
Craftsman Rethreader 52105 $46 Ebay *
Axtell Oil Bypass Valve 620-103(Zippers) $80 *
SPI 4"Dial Indicator Depth Base $25 Tool Connection *
Assembly Lube(Red Line/Torco/SE) *
Brake Cleaner and/or Elect Contact Cleaner *
Popsicle sticks */*Pipe cleaner(s) *
Torque Adapters: 3/8",*7/16", 1/2" *
Vise with soft jaws *
1/8" punch *
12 point deep sockets *
Heavy Duty Baggies for parts*
Three Bond 1184 sealer *
Silicon Spray *
1/2" ID hose for cylinder posts *
Hayden M6 BT07 Primary Chain Tensioner $105 Amazon *
Piston Ring Compressor $19 Auto Store *
* Purchased/in hand
Old Jan 17, 2014 | 09:14 AM
mattVA's Avatar
mattVA
Can't wait to see what some of those tools are for. You went all out especially with that run out tool.
Old Jan 17, 2014 | 10:39 AM
HD Pilot's Avatar
HD Pilot
Back to work, finishing the "Stripping Motorcycle For Service" procedure. Those ratcheting Sears wrenches are great for tight spaces - removing top engine stabilizer:
Old Jan 17, 2014 | 11:08 AM
HD Pilot's Avatar
HD Pilot
SE Intake tool - not necessary but extremely handy:
Old Jan 17, 2014 | 11:23 AM
HD Pilot's Avatar
HD Pilot
Had to use a Ball Allen extension to get the front 2 bolts - ouch!
Old Jan 17, 2014 | 11:45 AM
HD Pilot's Avatar
HD Pilot
SE Rocker Cover tool - highly recommended. Removing rocker covers per HD SM sequence:
Old Jan 17, 2014 | 12:08 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Fair warning..better knock some pixels off the camera setting or by the time you finish, this thread is going to be like peewee's great adventure with tats....You and Soft have soft hands? HA...Hope that condition does not spread to VA
Old Jan 17, 2014 | 12:15 PM
128auto's Avatar
128auto
Finally eh? Good luck buddy, follow the FM youtube video, you will get it going in a week at the latest. LOL
https://www.hdforums.com/forum/dyna-...-pictures.html
Old Jan 17, 2014 | 12:16 PM
128auto's Avatar
128auto
Nice tool! The two manifold bolts drove me crazy!
