Engine Build Time
Old Jan 17, 2014 | 12:18 PM
  #31
128auto's Avatar
128auto
OMG! Impressive!
Originally Posted by alansummrs
Here is my Parts/Tools list as it stand now. If I need to update it as this build goes forward, I will.
Throttle Body: HPI 55 1.80*,*new HD seals*
Cams: Tman 590 $377
Cam Bearings: Torrington B-168 Heartland $17**
Inner Cam Bearing Remove/Install: Heartland*$100 *
Oil Pump alignment screws (2) Heartland*
SE wrenches(3), ACR tool, SE Lifter holders, SE Pushrod tool $167(all*)
Cam Locking Tool $20 Ebay *
Piston Ring expander $8 Auto Store *
3/8" Socket "ball end" Allen long wrench 3/16" *
Cam Spacer Kit: HD 25928-06 *
Exhaust Gaskets: HD SE flat *
Pushrods: 1) S&S Quickee Adjustable Cover kit $182*106-6051 *
Lifters:*S&S Prem High Perf w HL2T 330-0174 $260 *
Headwork:*AMS CNC 1.900 Intake 1.610 or 1.575 stock Exhaust valves, .600 AV&V max lift springs
Feuling Pinion Shaft Run Out Tool $101 #9015 *
Big Bore:*AMS 107" .060 over bore
Compression Tester: OTC 5606 $52 Amazon *
Breather Filter*/tubing/clamps/caps
Tappet Block Centering Screws(rocker boxes) - the oil pump ones should work *
Engine Oil: Dyno for break in 20-50W*(5-30W?)
HD cam and top end gaskets *
Kent Moore Circlip installer EN-46745 $70 Ebay *
Craftsman Rethreader 52105 $46 Ebay *
Axtell Oil Bypass Valve 620-103(Zippers) $80 *
SPI 4"Dial Indicator Depth Base $25 Tool Connection
Assembly Lube(Red Line/Torco/SE) *
Brake Cleaner and/or Elect Contact Cleaner *
Popsicle sticks */*Pipe cleaner(s) *
Torque Adapters: 3/8",*7/16", 1/2" *
Vise with soft jaws *
1/8" punch *
12 point deep sockets *
Heavy Duty Baggies for parts*
Three Bond 1184 sealer *
Silicon Spray *
1/2" ID hose for cylinder posts *
* Purchased/in hand
Old Jan 17, 2014 | 12:19 PM
  #32
128auto's Avatar
128auto
Thought you already had 107?
Originally Posted by soft 02
I'm on a temporary ban from HTT for a video I posted. I'm pulling my motor today and got my new 107 kit from FM yesterday. I should be running in a week.
Old Jan 17, 2014 | 12:22 PM
  #33
mattVA's Avatar
mattVA
SE Intake tool - not necessary but extremely handy:
I hear this works really well too:
https://www.denniskirk.com/intake-ma...prd/H28700.sku
These are the kinds of threads that truly make the forum worthwhile. Keep the shots coming Alan.
Old Jan 17, 2014 | 12:23 PM
  #34
soft 02's Avatar
soft 02
Broke a wrist pin clip and pin slid over into the cyl. FML.
Old Jan 17, 2014 | 12:27 PM
  #35
HD Pilot's Avatar
HD Pilot
OMG! Impressive!
I was hoping you would drop in!!
Making progress, throttle body off, and rocker covers off. The gaskets on the rocket covers were stuck on pretty well, used a sharp edge box cutter and gently pried them off, still will need to clean up the gasket surface quite a bit.
Old Jan 17, 2014 | 12:28 PM
  #36
128auto's Avatar
128auto
How did it happen? Please don't scare me
Old Jan 17, 2014 | 12:55 PM
  #37
HD Pilot's Avatar
HD Pilot
These types of experiences(including your struggle with the circlips) drove me to buy the circlip tool, hopefully it will help me with those tricky devils!
Old Jan 17, 2014 | 01:00 PM
  #38
mattVA's Avatar
mattVA
Is the cam chest next. .? Or are you cutting out your PR's. I cut mine doing cams, haven't done rocker boxes before but know you have to get to TDC to take it off.
Edit: Nevermind. Can just lift the PR tubes to find TDC.
Alan,
Can we get a live stream setup? Just prop that cell phone up so we can tune in. . .
Old Jan 17, 2014 | 01:15 PM
  #39
128auto's Avatar
128auto
Soft02
You got me worry now coz I had a hard time installing the circlip, took me a few attempts. hopefully I didn't screw anything up. So what did you do to the clip? Are you saying they weren't in place? I am sure I did but the clip tension might have gotten soft after a few installation. Cross my fingers!
Old Jan 17, 2014 | 01:19 PM
  #40
soft 02's Avatar
soft 02
Soft02
Dont know how. It snapped in then at around 10k it made the bad noise. Done many of them so its not like it was my first time. Luck of the draw. Going to try and find a set of spiral clips instead. HD tool doesnt work with the 107 kit I was told.
https://www.google.com/search?q=spir...ih=997&dpr=0.9
