Engine Build Time
Old Jan 17, 2014 | 02:32 PM
  #41
HD Pilot's Avatar
HD Pilot
Originally Posted by mattVA
Is the cam chest next. .? Or are you cutting out your PR's. I cut mine doing cams, haven't done rocker boxes before but know you have to get to TDC to take it off.
Edit: Nevermind. Can just lift the PR tubes to find TDC.
Alan,
Can we get a live stream setup? Just prop that cell phone up so we can tune in. . .
No live stream! My pace would be too boring
Trying hard to get to cam chest to do the crank run-out but taking the top off first to just pull prs out. I really was hoping to get these cylinder heads and cylinders to AMS by tomorrow - might not happen.....
To find TDC for me: 6th gear, rotate tire, exhaust pr up - down, intake pr up - down, straw in spark plug hole, continue rotating tire to get the straw as high as possible and feel the air rushing out of spark plug hole - BINGO TDC Compression.
First Rocker Arm Support Plate out.
Old Jan 17, 2014 | 03:02 PM
  #42
HD Pilot's Avatar
HD Pilot
I used this SE tool to release the pr spring cap retainer - still managed to draw more blood learning how to use it. It helped but not a lot, I think someone needs to demo it to me, or else I could have used something else just as easily.
Old Jan 17, 2014 | 03:03 PM
  #43
Suede Blue Man's Avatar
Suede Blue Man
Good show so far, I'll watch this channel more often!
Old Jan 17, 2014 | 03:32 PM
  #44
mattVA's Avatar
mattVA
Alan, I just use a flat blade screwdriver to remove the tubes? Pretty easy to do just put in the slot and twist.
Old Jan 17, 2014 | 03:34 PM
  #45
128auto's Avatar
128auto
I too use a flat head screwdriver. Wow Alan is well prepared!
Old Jan 17, 2014 | 03:38 PM
  #46
HD Pilot's Avatar
HD Pilot
All right, made it to the cam chest. Had to use a rubber mallet gently to get the cam cover to release. The gasket came off with ease:
Old Jan 17, 2014 | 04:05 PM
  #47
HD Pilot's Avatar
HD Pilot
Outer cam tensioner off, marked the outside of chain with a zip tie, and have inserted the Crankshaft/Camshaft Sprocket Locking Tool - can go without this tool by holding rear brake pedal but I found it pretty cheap on Ebay and got it:
Old Jan 17, 2014 | 04:08 PM
  #48
128auto's Avatar
128auto
Hey Alan, you have my cell number right? Let's facetime lol
Old Jan 17, 2014 | 04:50 PM
  #49
128auto's Avatar
128auto
LOL nice talking to you on facetime, good luck with your engine build! Proud of you!
Old Jan 17, 2014 | 04:52 PM
  #50
HD Pilot's Avatar
HD Pilot
Cam plate off:
Inside cam chest:
