Engine Build Time
Old Jan 21, 2014 | 09:46 AM
  #141
mattVA's Avatar
mattVA
Originally Posted by alansummrs
These sounds like a good plan, I had heard several times that the Timken is somewhat of an overkill, might save some $$. Can you tell me exactly what a "lefty" is for my bike? Thanks, again.
SE lefty style bearing. It's basically the same bearing that's in there now but 'beefed up'. FYI, the SE 120R motor comes with the SE 'lefty' preinstalled in the left case half, and you don't read about it failing in that application. Instead of setting endplay like for the Timken you press out your old bearing and press in the new, and re-assemble.
  #142
soft 02's Avatar
soft 02
The lefty is a heavy duty roller bearing that replaces the OEM one and you install them on both sides. They should be stock but they are not. With a ballanced crank they should never fail. I had a bad crank and rods but my stock crank bearings looked great at 126k. Splitting the cases is easy on your motor. Much easier than a B motor.
Old Jan 21, 2014 | 09:48 AM
  #143
soft 02's Avatar
soft 02
Lefty bearing.
http://www.harley-davidson.com/store/se-lefty-bearing
Old Jan 21, 2014 | 09:52 AM
  #144
HD Pilot's Avatar
HD Pilot
Originally Posted by mattVA
I think I understand. Plan A is to use the Indy. You were contemplating doing it yourself (the splitting and re-assembling). If he knows what he's doing and has a good reputation and communicates with you I think you'll be happy with the outcome.
Getting close Matt! No, I never wanted to split the case case myself, because I knew someone else would have to install the bearings, so I was always wanting that "somebody else" to split and reassemble for me.
Maybe soon all this stuff will seem more easy to me. I have come a long way in about 16 months of owning my Fat Bob. I never did anything on my cars except change the oil(sometimes) before the Harley. It is addictive to me, I love being involved with a project - planning, reading, and executing. I just try to be a little realistic on my skills as I know there is a lot to learn and I do not want to get in over my head.
Old Jan 21, 2014 | 09:53 AM
  #145
mattVA's Avatar
mattVA
Looking at the parts diagram for a 2012 FXDF it appears the Lefty bearing is already installed on your bike.
Edit: In both case halves too. Lucky you.
Old Jan 21, 2014 | 10:05 AM
  #146
HD Pilot's Avatar
HD Pilot
Originally Posted by senna
I agree with dji, send the whole bottom end in. Mine is there now. Crank true,weld,plug and ballance. Plus H beam rods and timken conversion with blue print reassymble.
And, I agree with you on having to stop spending money some where. I stopped at 107, figureing if I went to 117 I would need a larger TB new cylinders and possibly a switch to chain drive if you atart tearing up belts
Thanks for jumping in! I have read a few of your posts about your build but cannot remember exactly what all you are doing; cams, headwork, etc?
Old Jan 21, 2014 | 10:11 AM
  #147
senna's Avatar
senna
I am doing a FM 107, TW777 cams, level B heads and ported TB.
Like I said, I am having DH do a complete Bottom end. That includes, balanced, trued, plugged and welded crank. H beam rods and Timken conversion.
some might say the rods and Timken are over kill. I will feel a lot better this way. I hate that nagging feeling I get when I question if I should have done this or that. I eliminated the possibility of that nagging feeling.
Old Jan 21, 2014 | 10:12 AM
  #148
HD Pilot's Avatar
HD Pilot
soft 02 attachment shows part 24004-03B, my part book has part 24605-07
Old Jan 21, 2014 | 10:14 AM
  #149
HD Bobber's Avatar
HD Bobber
having just lefty bearings is way better than stock crap (ALLAN is lucky enough that the 2013's seem to have the lefty now) but it still has plenty of room to walk.
TIMKIN locks your crank into place and sets it! Simple as that. If youre going through all the trouble of having DH split & true everything you might as well get the Timkin (around an extra $500 through DH). Not cheap, but money well spent for added insurance of all the truing and balancing.
Old Jan 21, 2014 | 10:27 AM
  #150
mattVA's Avatar
mattVA
24605-07 is the bearing in kit 24004-03B.
