Engine Build Time
Old Mar 28, 2014 | 08:32 AM
  #521
maddghost's Avatar
maddghost
Originally Posted by alansummrs
I used a 3/32(.09375"), stock was .060", most threads I have seen do not go any larger than 1/8(.125"). I have had a very small amount of oil show up at the bottom of my oil filter and backplate area.
Well your building that motor to have fun with When you start twisting it is when the seepage occurs!
I've had my little 107 stage II up to 136 MPH, cars 1.5 miles ahead started to look like they were just stopped! That scared me enough to take it way back down to 90!
"NJOY!
Old Mar 28, 2014 | 09:09 PM
  #522
target64's Avatar
target64
Originally Posted by maddghost
To what size did you boar out those holes alan? I beleive mine were enlarged to either 5/32ths' but there is still oil on the arlen ness back plate whenever I remove it for cleaning. On oil change I usually add the proscribed amount but I never add until she is below halfway up cold, and then onlt to 3/4 full on the dipper.
Scott the holes where 1/8 in the rocker arm supports.
Old Mar 29, 2014 | 12:14 AM
  #523
dirtdobber's Avatar
dirtdobber
2" should not be a problem but I guess it did make things pretty tighWell I had my heads decked .032" and using a .030" Cometic vs a .045" stock head gasket. I had read that .03t. I really hope it will be good, did not have to force it too much - I put the end of my ball allen T wrench on the side of the manifold flange and with my other hand I "bumped" the flange toward the primary side and then threaded my fasteners in. I will give it a good check when I start it up, if I have any leaks, how much to you normally remove from the manifold runners?
Really good info, thanks.
If the close tolerances work for you, you will be ahead in the long run.
Old Mar 30, 2014 | 07:02 PM
  #524
HD Pilot's Avatar
HD Pilot
Got the HPI tb on and all connected up. Put my ac, horn/engine stabilizer, fuel tank, and adjusted my throttle cables. Tomorrow I need to put the battery back in, exhaust on, seat on, compression check and fire it up has been a long haul, pretty nervous about hitting that start switch
Old Mar 30, 2014 | 07:07 PM
  #525
HD Pilot's Avatar
HD Pilot
"NJOY!
I would be pretty nervous at 136 mph too, a ticket there would set ya back a little to boot! I kinda like the idea of 0 to 80 as fast it will go, leaving a little rubber
Old Mar 30, 2014 | 07:33 PM
  #526
mud's Avatar
mud
don't light it up until you see oil pressure.
Old Mar 30, 2014 | 08:47 PM
  #527
HD Pilot's Avatar
HD Pilot
No oil pressure gauge, have oil indicator lamp that should go out when engine speed is above idle - not sure if I can make that light go out during a compression check or not
Old Mar 30, 2014 | 09:05 PM
  #528
vdop's Avatar
vdop
It's always good to prime the motor. With the plugs out and fuel line disconnected crank it over. I only crank it for 10 seconds or so at a time to be easy on the starter. It will build pressure and the light will go out on the second or third try if all is well. You can usually hear the lifters pump up and stop ticking while it's cranking, then it should start up nice and quiet.
Old Mar 30, 2014 | 09:17 PM
  #529
HD Pilot's Avatar
HD Pilot
More great info, will do!
Old Mar 30, 2014 | 09:22 PM
  #530
SLV's Avatar
SLV
Can't wait to read about the results. I wish I could actually hear the results. Good luck!
