Engine Build Time
Old Mar 27, 2014 | 07:43 PM
  #511
HD Pilot's Avatar
HD Pilot
Got my HPI tb on finally, was a true pain in the ***. Trying to get the cam side flange holes to line up with the cylinder head holes was very frustrating. I was very careful though and took my time being careful not to cross thread those 2 fasteners. Now I know where the dings came from on my flanges(I bought a used HPI tb), they come from the previous installer banging on the flanges to line up the holes. I tried to be as gentle as possible but found that the flanges had to be "bumped" into position so you could safely thread the fasteners in.
Old Mar 27, 2014 | 07:53 PM
  #512
mud's Avatar
mud
it's really simple if you start your manifold bolts loosely before you torque the heads down
Old Mar 27, 2014 | 09:43 PM
  #513
HD Pilot's Avatar
HD Pilot
That's definitely a new idea for me. Wonder if it is easier because the heads are a shade loose or because you have more room without the rocker housings/covers in the way or maybe both? The heads sure seem to go onto the cylinders tightly with those dowels but I do think having more room for my big hands would help....maybe next time, hopefully in a long time.
Old Mar 27, 2014 | 10:18 PM
  #514
YAZOO's Avatar
YAZOO
You have to take one end of the cross over tube loose. stick a pencil in the hose and put a rubber cap on tnk spigot. leave gas in tnk
Old Mar 27, 2014 | 10:22 PM
  #515
vdop's Avatar
vdop
Easiest way to get the intake bolts in is with the rocker boxes off for a straighter shot and a ball allen with long extension. But if you're having trouble getting the holes lined up it's most likely because of the height of the heads. Depending on how much you deck the heads the manifold can be too wide. As you take material off and use thinner head gaskets you drop the heads, they get closer together and you have to remove material from the end of the manifold runners. The 2 piece hpi's are really nice because you can pull the throttle body off and line up just the manifold and flanges while looking from the inside until you get the ports and bolt holes lined up perfectly. If anything needs to be forced or struggled with or left loose to make fit then there's a problem and an interference. The throttle body should pretty much fall into place when fit correctly.
Old Mar 27, 2014 | 10:42 PM
  #516
HD Pilot's Avatar
HD Pilot
Well I had my heads decked .032" and using a .030" Cometic vs a .045" stock head gasket. I had read that .032" should not be a problem but I guess it did make things pretty tight. I really hope it will be good, did not have to force it too much - I put the end of my ball allen T wrench on the side of the manifold flange and with my other hand I "bumped" the flange toward the primary side and then threaded my fasteners in. I will give it a good check when I start it up, if I have any leaks, how much to you normally remove from the manifold runners?
Really good info, thanks.
Old Mar 27, 2014 | 10:43 PM
  #517
soft 02's Avatar
soft 02
Just tighten it till it loosens up....
Old Mar 27, 2014 | 11:24 PM
  #518
HD Pilot's Avatar
HD Pilot
That does make sense, so simple too. With the new seals and all.
Old Mar 28, 2014 | 05:05 AM
  #519
maddghost's Avatar
maddghost
Oil should go back in the pan through the holes I enlarged on the rocker supports. Anyway, a good discussion for sure, enjoying the feedback
To what size did you boar out those holes alan? I beleive mine were enlarged to either 5/32ths' but there is still oil on the arlen ness back plate whenever I remove it for cleaning. On oil change I usually add the proscribed amount but I never add until she is below halfway up cold, and then onlt to 3/4 full on the dipper.
Old Mar 28, 2014 | 07:44 AM
  #520
HD Pilot's Avatar
HD Pilot
I used a 3/32(.09375"), stock was .060", most threads I have seen do not go any larger than 1/8(.125"). I have had a very small amount of oil show up at the bottom of my oil filter and backplate area.
