Engine Build Time
Old May 14, 2014 | 08:57 PM
  #621
HD Pilot's Avatar
HD Pilot
Hopefully this link will work, first time posting a video.....
After engine build:
Old May 14, 2014 | 09:02 PM
  #622
Suede Blue Man's Avatar
Suede Blue Man
That sounds like quite a beast! I can't imagine trying to sneak by a cop quietly on that!
Old May 14, 2014 | 10:07 PM
  #623
HD Bobber's Avatar
HD Bobber
Very nice Allan! That pipe sounds mean as hell, can't imagine the beast screamin near redline!
Man I have heard motors with & without head work and what a difference in sound when a bike had the heads done up. Enjoy the hell out of the beast!
.....got a bit over 550 miles on mine and can't wait to dyno it.
Old May 14, 2014 | 10:31 PM
  #624
HD Pilot's Avatar
HD Pilot
I am worried about that, the build made the already loud Bassanis louder!
Old May 14, 2014 | 10:37 PM
  #625
HD Pilot's Avatar
HD Pilot
Having a blast, frigin roars!
The dyno tune really makes the power on and off feel smooth, I just plugged up my O2 ports - not even gonna try an Autotune.
Just got my Trick Shift Synthetic ATF today, new frictions and steels should be in pretty soon.
Old Oct 30, 2014 | 03:55 PM
  #626
HD Pilot's Avatar
HD Pilot
Been over 5 months since my last post so I thought I would update the thread:
Installed the Alto Carbonite clutch plates, Baker manual primary chain adjuster, and the Trick Shift Synthetic ATF. Clutch seems to be holding fine but something in this change has made finding Neutral harder when at a stop.
Did a Compression check not long after the build was complete and came up with ~ 185 psi for front and back. It was good that there was hardly any difference between front and back but the total psi was about 10 psi short of my target. After running a thread about compression checks over at the HTT Forum I learned a lot more about how to do a compression check:
1) Run the engine for a couple of minutes just to make sure all the oil in the engine is properly distributed.
2) Make sure your battery is 100 percent charged up - a standard HD tender is inadequate. I bought a $50 Deltran 1.25 Amp Battery Charger/Tender and a Digital Multimeter to run a load test to insure the battery was OK.
3) Having some miles on the build and broken in etc, could help the check.
So anyway I redid the Compression Check and came up with ~ 195 psi just as I had planned using my info and the Big Boyz Compression Calculator.
If you have followed this thread you will recall that I was a bit disappointed with the Dyno results. Not so much the max #s of 104hp and 112tq but the torque dip from about 2300 to 2800 rpms. Well I and Steve(GMR) felt that the shorter Bassanis were probably the problem. Well I had spent enough $$ at the time so did not feel like buying new pipes right away but now I am ready and hope I have the best choice for my build/tastes:
Old Oct 30, 2014 | 03:58 PM
  #627
soft 02's Avatar
soft 02
You'll like em! P.S. good thread on compression. I lerned a bit too. I wont do a compression check for a while. I did do a leak down test though. Are you going to re dyno or just auto tune?
Old Oct 30, 2014 | 04:03 PM
  #628
HD Pilot's Avatar
HD Pilot
Waiting for Steve to call me back, hoping to schedule the dyno for Nov 13th or 14th. I think when you go this far into engine work, ATs just don't cut it, plus after riding the bike after Steve tuned it....well let's just say I was very happy!
Old Oct 30, 2014 | 04:20 PM
  #629
soft 02's Avatar
soft 02
Yup. If id have gone with auto tune pro for mine id have another boat anchor because I wouldnt have figured out the fuel pump was bad till it was too late.
Old Oct 30, 2014 | 06:38 PM
  #630
senna's Avatar
senna
You are going really like the D&D. If you remember we did our builds around the same time. Mine has been flawless and I have been really enjoying it.
Road over to Reno last month and had an awesome time on the first long ride. My brother rides a stage one 103, when we stopped for fuel we would literally use the same amount of fuel. 40 MPG
