Engine Build Time
Old Mar 7, 2014 | 10:00 AM
  #391
HD Pilot's Avatar
HD Pilot
Originally Posted by mattVA
Good deal. Do you have to do any Piston/valve measurements before moving on. . .? Claying the motor etc?
You sure know what is grinding around in my brain
AMS told me no worries, but that was with a .008" in the hole deck height. Here is my plan(as of this moment in time...): Install the rear cylinder and get its' deck height, call AMS and see if they can get me the .030" head gaskets - if so, no claying, if not then I will discuss the situation with AMS and decide.
Just wondering, does claying ruin your head gaskets?
Old Mar 7, 2014 | 10:01 AM
  #392
soft 02's Avatar
soft 02
Just add .030 or whatever to the measurements you come up with.
Old Mar 7, 2014 | 10:04 AM
  #393
srt8's Avatar
srt8
1 time use on head gaskets after you squish em they are done X2 on what soft02 said
Old Mar 7, 2014 | 10:09 AM
  #394
HD Pilot's Avatar
HD Pilot
So you torque the heads down without head gaskets? Or maybe just a light torque?
Old Mar 7, 2014 | 10:20 AM
  #395
mattVA's Avatar
mattVA
Alan,
I'm just asking questions. .nothing more
This is the one area of building a motor I've been somewhat confused on. You've gotten the cylinders on with new pistons, you can tell they're x amount below flush at TDC, now what? How do you know the valve with a higher lift cam won't contact the piston eyebrow etc, and if it does. .bigger head gasket? Please post your findings (either from AMS or from elsewhere) as I'd like to know.
Matt
Old Mar 7, 2014 | 10:47 AM
  #396
srt8's Avatar
srt8
Alan,
Matt
Bingo…..you have hit on the magic part of race motor building...will it go boom? ….. to find out there are several ways to find out you can do the math based of measuring everything or you can go direct route by measuring an assembled motor. one way in to assemble and full torque the bolts bring piston to TDC and using a very low pressure valve spring push the valve down til it contacts and take a measurment subtract that from your total cam lift at the valve and thats your clearance. Another methode would be the model clay fully mocked up motor run it through a complete cycle take apart and measure the thickness of the clay on the piston I am sure there are more methods those ar the ones I know of
Old Mar 7, 2014 | 10:52 AM
  #397
HD Pilot's Avatar
HD Pilot
Matt I read a lot on this subject then backed off when AMS told me no worries. Several things have big impacts on whether you decide to clay or not. One of the biggest reasons I did a 107" BB was to get the pistons with bigger valve reliefs - these pistons(CP) are used with much bigger cams than I chose, so confidence there. Also, the valve lift at TDC Compression is the # that counts, so if you pick a cam with a relative normal # there it helps. Then of course the squish/quench clearance as you have brought up, if you use a more common amount say .035" to .040" then less worries. Lastly, and probably most importantly is the shops' experience doing your heads and cylinders - no telling how many motor builds AMS has done and Eric did not flinch at all when I brought this subject up even with shaving .032" off my heads for compression. Of course the conservative thing to do is to go ahead and clay it, just adds more time.... And at my pace......
Here is a reference that is interesting:
http://www.nrhsperformance.com/tech_valvetopiston.shtml
Old Mar 7, 2014 | 10:59 AM
  #398
srt8's Avatar
srt8
Matt I read a lot on this subject then backed off when AMS told me no worries. Several things have big impacts on whether you decide to clay or not. One of the biggest reasons I did a 107" BB was to get the pistons with bigger valve reliefs - these pistons(CP) are used with much bigger cams than I chose, so confidence there. Also, the valve lift at TDC is the # that counts, so if you pick a cam with a relative normal # there it helps. Then of course the squish/quench clearance as you have brought up, if you use a more common amount say .035" to .040" then less worries. Lastly, and probably most importantly is the shops' experience doing your heads and cylinders - no telling how many motor builds AMS has done and Eric did not flinch at all when I brought this subject up even with me shaving .032" off the heads for compression. Of course the conservative thing to do is to go ahead and clay it, just adds more time.... And at my pace......
with the build you are doing being so common as it is, the piston manufacturer usually tells you piston good up t X lift anyway and AMS having done so many I am sure you can rely on their word I think the only thing you might want to know is what is your actual squish which you can measure with the motor dissassembled
Old Mar 7, 2014 | 02:34 PM
  #399
HD Pilot's Avatar
HD Pilot
Hardly any time to work today, but was able to install the rear cylinder in about 1/4 the time it took yesterday - much better with the Kramm-Lox and the ring compressor is very nice:
Looks like I'm about .003" down on the rear cylinder too. Anybody else notice that aftermarket pistons bring up the deck height .005"?
Old Mar 7, 2014 | 11:08 PM
  #400
senna's Avatar
senna
IIRC the CP pistons have a compression height of 1.085" not sure what stock is?
When I did my bottom end I used the H beam rods. Seems these are a bit longer than stock as well. My pistons were out of the hole +.006, I had to get the .040" head gasket.
