Grip Install
Old Apr 8, 2014 | 05:15 PM
jmb79's Avatar
jmb79
Can't say anything about the grips the OP has purchased, however, with the Kuryakyn ISO grips I have, the clutch side grip fits inside the switch housing but that alone will not keep it in place. It is still required to to use an adhesive inside the grip to glue it to the handlebar. Also, the adhesive supplied by Kuryakyn is useless.
Old Apr 8, 2014 | 09:04 PM
loopie's Avatar
loopie
too remove old grips take off your bars leaving left side grip on. boil some water and put the water in a jar or some thing tall, insert the grip/bar in hot water in under a minute the glue will soften then you can pull off the grip with out damage,,, same for the throotle side
Old Mar 28, 2015 | 12:14 AM
NAILIT RK's Avatar
NAILIT RK
Just bought some HD grips for my RK. Bought the same style that was on it. I noticed the new ones were designed a bit differently. First the old ones had more rubber (softer). And clutch side was glued on. New ones are harder plastic and on the clutch side the portion that fits inside the switch housing is shaped different the grip has to be rotated correctly or the switch housing won't mate together properly. Once the grip is rotated and housing tightened down the grip is locked in place. No glue needed, No instructions and no glue supplied with the grips to begin with.
Highgrade
Jul 12, 2015 11:13 AM
Dually_TG
General Topics/Tech Tips
Aug 16, 2012 01:16 PM
jcanrun
May 17, 2010 12:01 PM
LoRyder
May 24, 2007 06:16 PM
Hossman
May 15, 2006 02:17 AM
