Ricon Intiminators & fork fluid change
Old Sep 3, 2014 | 07:44 PM
vern58's Avatar
vern58
Default Ricon Intiminators & fork fluid change
Getting ready to drop in a pair of Intiminators and reinstall forks. Can anyone tell me whether the fork oil measurement is taken with the forks off the bike in a vertical position, or mounted in the trees in the raked position. Also any ideas on the distance the top of the forks should protrude above the top tree.
Old Sep 3, 2014 | 08:43 PM
HD Pilot's Avatar
HD Pilot
Vertical position. .575" to .675" above the top clamp(distance is to the top of fork cap). Info from 2012 Dyna SM.
monster715's Avatar
monster715
Should be done off the bike in a vertical position with the forks compressed. Make sure to pump the slider several times to pump the air out. I took my measurement with the ricors in the tubes
Old Sep 3, 2014 | 08:45 PM
monster715's Avatar
monster715
Originally Posted by HD Pilot
Vertical position. .575" to .675" above the top clamp.
That measurement should be from the top of the clamp to the top of the caps (not the tubes ) correct?
Old Sep 3, 2014 | 09:29 PM
vern58's Avatar
vern58
Thanks guys.
Old Sep 3, 2014 | 09:35 PM
HD Pilot's Avatar
HD Pilot
Yes, you might have caught me just prior to my edit making it more clear.
Old Sep 3, 2014 | 10:21 PM
vern58's Avatar
vern58
One last question...with the intiminators installed, do I need to shorten the spring collar (the metal tube surrounding the spring)? Will the factory length make it a pain to secure the fork caps?
Old Sep 3, 2014 | 10:26 PM
misfitJason's Avatar
misfitJason
I did this just a week ago.
This is the way I did it and I am not saying it's correct or the best way
I took the measurement with the intiminators in and what the manual said 110mm
I did not shorten the spacer and yes it was a pain to get the caps on but to be honest I don't notice any difference between the stock and now except for the obvious difference of the intiminators
Old Sep 4, 2014 | 07:42 AM
californiafatbob2013's Avatar
Default Intiminator ????????????
The Intiminators are 1/2" in height, you should shorten the stock spacer by that amount or you may end up with to much pre-load..........
Live Free = Ride Free............
AllenW
Apr 7, 2016 06:46 AM
Hawk2K
Sep 6, 2012 03:27 PM
IlDuce
Shovelhead
Jun 18, 2010 12:43 PM
halmc
EVO
Mar 15, 2010 06:03 AM
hennyhog1
Oil Archive (no new posts)
Apr 11, 2007 09:23 AM
