LED Brake light causing red "warning" light on speedo
Old Aug 19, 2018 | 08:47 AM
HighCountry's Avatar
HighCountry
Default LED Brake light causing red "warning" light on speedo
I replaced my brake light bulb with an LED bulb and now the red warning light is coming on next to the speedo... I've done a search but didn't find a fix. Can the bike be programmed to "see" the LED? or can a load equalizer be installed in the witing? I've had to do this with LED turn signals, but never a brake light... Evidently, the computer is getting "smarter"???
If I missed a post that answers it, my apologies, please point me in the right direction.
And thanks in advance...
Old Aug 19, 2018 | 08:54 AM
Noisy Cricket's Avatar
Noisy Cricket
What LED's do you install? I have the CD LEDs both front and back in my 19 RKS and they work flawlessly.
Old Aug 20, 2018 | 07:58 AM
HighCountry
No brand name, but I've used the same bulbs on my '03 and they work perfectly as well.
Old Aug 20, 2018 | 10:47 AM
bustert's Avatar
bustert
is the bulb you pulled a bulb for "can" system? if so, it maybe seeing it as a bulb out if that is a system on your machine. there is a work around so google it, will be for auto but will apply.
Old Aug 20, 2018 | 12:41 PM
Zanthamos's Avatar
Zanthamos
03 non Canbus 18 is Canbus and needs compatible bulbs.
Old Aug 20, 2018 | 06:17 PM
HighCountry
Thanks guys... I obviously didn't think about that... Is there a workaround for our scoots, or should I just get a new bulb??? I'm hoping the former as this bulb looks great!!!
Old Aug 21, 2018 | 11:12 AM
Zanthamos's Avatar
Zanthamos
Maybe contact customer support for the company and see if they have a CANBUS adapter.
Old Aug 22, 2018 | 09:57 AM
HighCountry
They don't, they suggested a resistor... If there's no way to program the computer to "see" the bulb, then I'll probably just look into buying a different bulb. Bummer...
OddJack
Sep 5, 2014 07:37 PM
2003Custom1200
Sep 1, 2012 05:50 AM
redsled
Nov 12, 2011 06:54 PM
PopsHD
Nov 9, 2010 06:49 PM
ELGOLD
Apr 14, 2008 11:04 PM
