2017 Softail Slim S Ground Issue
Old Dec 28, 2019 | 04:18 PM
Reaper21's Avatar
Reaper21
Default 2017 Softail Slim S Ground Issue
So lately my bike has had a hard start. When I go to start the bike it almost sounds like it’s dead and pauses then cranks over. Thought it was the battery. I got a new battery and it has done the same thing. I have checked all the grounds from the battery, they are all tight.
Where else could I have issues?
I read somewhere about a ground under the oil tank possibly but don’t know what I am looking for.
I do have videos of me starting it and what happens. Also my odometer changes from what I have it set to back to the mileage on the bike like it resets.
Old Dec 28, 2019 | 10:34 PM
Crotonrz's Avatar
Crotonrz
Your ground cable should go from your battery to the left ground bolt directly in front of it, it's easily accessible there. Otherwise, disconnect the battery, and make sure the starter positive cable is tight, it's on the starter, under a rubber cap, and is not the most accessible thing, even grabbing it and checking for tightness will do.
I'm assuming that if it's not a H-D battery, that you've used spacers and the correct bolts as necessary for the battery? We see a lot of loose connections from long screws, or missing spacers, and the cable end connections end up barely making contact.
Old Dec 29, 2019 | 07:47 AM
Reaper21's Avatar
Reaper21
Yes I’m thinking it’s the ground to the starter, both batteries are HD and everything is tight on top.
I am guessing it’s the ground on the starter because this only happens when I go to start it. I could start it just fine ride a good 20 miles pull into a gas station turn it off fuel up then go to start it again and it would click or do the same thing. Also not sure why the odometer keeps resetting. I like to watch either my RPM or the fuel I have left until empty and for some reason after I start it it jumps back to how many miles are back on the bike.
Old Dec 29, 2019 | 08:23 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Why would you only suspect the ground side of the circuit?
It takes two paths for the current to complete the circuit, Positive and Negative, both are equally important.
Check all connections, Positive and Negative, dont just try to wiggle them, take them apart and clean them.
Have the battery load tested.
Old Dec 29, 2019 | 10:29 AM
Reaper21's Avatar
Reaper21
Old battery was load tested and failed bought a new battery yesterday and installed it and it’s doing the same thing all connections positive and negative are tight
Old Dec 31, 2019 | 10:23 PM
Reaper21's Avatar
Reaper21
So tinkering around and after checking to make sure all connections were tight. Went to start it and once again a real hard start. My buddy was standing there and was like I wonder if it’s your starter. Took a dead blow hammer and tapped on the starter and went to start and BAM! It started it just normal no long dying start and everything seemed to be back to normal.
So most likely I guess the starter is going bad which I’m not sure why it would since the bike is only 3 years old.
My next question is, is the starter covered under warranty? I did get the extended warranty when I bought it.
Old Jan 3, 2020 | 05:56 PM
ghost183's Avatar
ghost183
starter is going bad on a 17 slim?!?! thats disappointing to say the least
check your wiring brother.. if the starter draws excessive amps due to bad connections, the next starter will do the same and eventually start the same song and dance.. something is up..
did you check the pos cable attached the starter solonoid? if you tapped the starter and everything is good now.. look into that cable
Old Jan 4, 2020 | 04:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Not just tight....Clean and tight.
Disconnect the battery cables at both ends, clean the connection points and reinstall the cables.
Remove the end cover of the solenoid and take a look at the contacts.
Get out your votmeter, and put your wallet away, it`s almost certainly not a bad starter motor.
gdon130
Engine Mechanical Topics
Aug 5, 2017 10:53 AM
sequel909
Electrical/Lighting/Alarm
Aug 3, 2017 04:00 PM
alcotune
May 23, 2016 08:27 PM
ironsheik
May 14, 2011 02:37 PM
Zap1990
Exhaust System Topics
Jul 31, 2009 07:30 AM
