Help with top end assembly
Old May 7, 2015 | 02:36 PM
Road Star's Avatar
Road Star
Default Help with top end assembly
Just trying to confirm, there is no cylinder base gasket, is there? Just an o-ring?
Old May 7, 2015 | 04:12 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Correct,just an O-ring.
Old May 7, 2015 | 04:41 PM
Road Star's Avatar
Road Star
Ok. Thanks.
BTW, what is the break-in procedure for new pistons?
Old May 7, 2015 | 06:29 PM
OldEnuf2NoBtr
The break-in for the new rings should be about 200-300 miles of laid back cruising varying the rpm's.
Old May 7, 2015 | 09:39 PM
Road Star's Avatar
Road Star
Is there any need for clear silicone sealant? It was on the list that came with my cylinders and pistons.
Old May 7, 2015 | 09:44 PM
QC's Avatar
QC
I did not use any sealer when I did mine.
Old May 7, 2015 | 09:55 PM
Road Star's Avatar
Road Star
This is what came with the kit.
Old May 7, 2015 | 09:59 PM
QC's Avatar
QC
Interesting, but mine from Hillside did not come with any nor was any recommended.
I can't think of where it would be used, either. I get the lube on the bolts and studs.
Old May 7, 2015 | 10:05 PM
rockajet1's Avatar
rockajet1
Originally Posted by Road Star
Ok. Thanks.
S&S says 50 miles under 2500 rpms w/ no constant rpms. Then an oil change.
Then 500 miles under 3500 rpms w/ no constant rpms. Then an oil change.
Then take it easy until you get to 1000 miles.
I recently completed the build noted in my signature. I did the 50 miles (and oil change) and made it til about 400 miles before I started riding it hard (meaning bouncing off of red line) this week. My buddys riding behind me didn't see any red hot pieces of piston ring or smoke coming out of my exhaust, so I think the rings are seated OK. Gonna change the oil and I'm getting it dyno tuned next week. I believe if it is put together right, what I did is more than adequate for a proper break in.
BTW, a friend got a 106 S&S set up done by T-man and rode it like he stole it right out of the shop and his runs great and doesn't smoke at 20K.
Good luck!
Old May 7, 2015 | 10:13 PM
Road Star's Avatar
Road Star
Thanks. Always nice to get another opinion.
