How big is BIG
Old Jun 19, 2015 | 11:21 PM
LAAM's Avatar
LAAM
1st Gear
Default How big is BIG
Looking to do some engine work to the CVO RK 2014. Would like to see what others have come up with, and what works and what doesn't .
Looking at or near 130hp has anyone gone there.
I've found one in Lebannon, MO at 180 hp but the picture shows some l
kind of aftermarket SC or Turbo, not what I would want.
Looking at Cam, pistons, bore ect
Thanks
Old Jun 19, 2015 | 11:39 PM
Uncle Chester's Avatar
Uncle Chester
Here's a thread that would be worth looking through if you haven't already. Gives you a good idea of what others have done and what to expect out of different combos.
For 130 hp though you'll probably need to do a little case boring.
https://www.hdforums.com/forum/touri...r-baggers.html
Old Jun 19, 2015 | 11:59 PM
cdonis's Avatar
cdonis
S and s 143 crate motor.
Old Jun 20, 2015 | 12:05 AM
Uncle Chester
Pair that with a Trask and it'll have all the power you'll ever need.
Old Jun 20, 2015 | 01:56 AM
Next In Line's Avatar
Next In Line
More effective to match the torque curve to your riding style than to chase numbers out of your rpm range.
Old Jun 20, 2015 | 07:43 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Thanks
A 117"(your cases bored to a accept S&S 4 1/8" cyls)can EASILY show 130 hp, and we have had them at 140 hp as well, w/o any power-adder devices such as blowers/turbos/nitrous.
Fellow forum member Target64's 107" pulls 129 hp, for example.
Scott
Old Jun 20, 2015 | 10:30 AM
0ldhippie's Avatar
0ldhippie
117 would be my pick too, but a 143 may be cheaper if ya can sell your motor.
Old Jun 20, 2015 | 10:36 AM
senna's Avatar
senna
Wouldn't a CVO bike already be a 110" motor?
Wouldn't a 110" already be larger cases?
I don't know specifics of a 110" motor.
Old Jun 20, 2015 | 11:09 AM
djl's Avatar
djl
Originally Posted by senna
Wouldn't a CVO bike already be a 110" motor? Wouldn't a 110" already be larger cases? I don't know specifics of a 110" motor.
The 110" cases will not accommodate the 4.125" cylinders; case boring is required. The OP should cut to the chase and spend a bit more money for the S&S 124" motor; the touring version would provide all the performance the OP could handle.
Old Jun 21, 2015 | 09:11 AM
lkr0's Avatar
lkr0
exactly cut to the chase with S&S 124 -- if you feel you need more - the S&S motor can take a lot of upgrades without sacrificing reliability
Originally Posted by djl
The 110" cases will not accommodate the 4.125" cylinders; case boring is required. Cut to the chase and spend a bit more money for the S&S 124" motor; the touring version would provide all the performance the OP could handle.
rhuff
Engine Mechanical Topics
32
Sep 11, 2015 10:32 AM
AnimalInstinct
Mar 13, 2015 01:24 PM
big-gun
Jan 26, 2015 05:24 PM
'10NIGHTGLIDE
Aug 25, 2010 02:39 PM
jtscuba02
Exhaust System Topics
19
Feb 11, 2008 08:58 AM
