2014 CVO Limited excessive vibration
Old Nov 11, 2015 | 07:28 AM
adippolito's Avatar
adippolito
1st Gear
Default 2014 CVO Limited excessive vibration
just bought it used, 2500 miles, aneew vance & hines full exhaust & screamin eagle tuner, was mapped. trailored it home about 120 miles. every gear high vibration, like driving over gravel or highway strips, while throttling up it smooths out & once you come off the throttle vibraton comes right back. vibration is much worse with 2 up versus 1 up. i also feel a random vibration rattle non-rpm related low on the bike.
Old Nov 11, 2015 | 09:33 AM
Next In Line's Avatar
Next In Line
Did you notice the vibration during the test ride?
Old Nov 11, 2015 | 10:24 AM
adippolito's Avatar
adippolito
1st Gear
no, took a short ride around the parking lot, the dealer put on a new exhaust, screamin eagle tuner & mapped (no dyno).
from i've been reading could be 1. motor mount 2. exhaust mount/interference 3. tuning/map
Old Nov 11, 2015 | 11:23 AM
djl's Avatar
djl
Could be any of those or worse; tweaked crank. If bought from a dealer, load it up on the trailer and take it back. It's a '14 model and still under warranty. Get the issue in the system now.
Old Nov 11, 2015 | 12:08 PM
adippolito's Avatar
adippolito
1st Gear
yep, it's already back there. i expect to hear back in a couple hours.
Old Nov 11, 2015 | 01:06 PM
Next In Line
If I were you, I would tell them to give me a full refund.
Old Nov 11, 2015 | 02:11 PM
adippolito's Avatar
adippolito
1st Gear
here's what they found, the exhaust was hitting the floorboard and a bolt was found lodged between the engine & frame. the extended the floorboard out a little. both of these issues I had read about as a potential cause
Old Nov 11, 2015 | 02:55 PM
djl's Avatar
djl
I love a happy ending.
NH_DRZ
Jun 25, 2019 09:12 PM
ZEROPILOT
Jun 6, 2019 03:52 PM
masplumber
Aug 20, 2016 06:02 PM
Slu
Dec 7, 2012 11:17 AM
beary
Jan 20, 2009 06:36 AM
