Revolution performance 113 kit
Old Feb 3, 2016 | 07:08 PM
fattyboyy's Avatar
fattyboyy
Default Revolution performance 113 kit
Has anyone used the revolution performance 113 kit? If so was it built well and did it last. Or is it of poor quality? I was thanking of putting this on my 08 fat boy this winter. What cams would you use it you were going to do this?
Old Feb 4, 2016 | 05:32 PM
fattyboyy's Avatar
fattyboyy
Anyone have any opinion on this company and there products?
Old Feb 4, 2016 | 05:57 PM
HD Pilot's Avatar
HD Pilot
**Deleted**
Was thinking about R&R Cycles, not Revolution Performance.
Old Feb 5, 2016 | 11:06 AM
Primetime_2's Avatar
Primetime_2
you have to open up the bottom to go that big so you may as well go to a 117/124. Crank will have to be addressed
Old Feb 5, 2016 | 12:52 PM
fattyboyy's Avatar
fattyboyy
The add said no splitting the case just like the new SE 110. That is what it said in the JP cycles book. This is why I won't some feed back from guys that are using it now.
Old Feb 6, 2016 | 05:35 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A "shop"(actually one-man-band) severly tarnished the RP cylinder reputation quite some time ago via using Chinese rings inside those nickel-plated cylinders, on 40-50 or so, 98" cylinder kits.
Scattered the hard nickel material thru the entire engines, creating a real mess.
Class-action law suit was in the works, but never materialized.
Same outfit can no longer purchase from Axtell, R&R Cycle, or Bob Wood.
That said, those cylinders seem to work fine.
Scott
Old Feb 6, 2016 | 06:45 AM
prodrag1320's Avatar
prodrag1320
we wont use nikasil plated cylinders here,too many problems in the past.like already stated,if your going to go thru the trouble of splitting the cases,ide go with a longer stroke & bigger motor.remember you can go 107" without boring the cases,ide do that
Old Feb 6, 2016 | 07:18 AM
Primetime_2
your sig says 08 fatboy with 103 jugs is this what you ride?
the 113 kits bolt onto 110 cvo's
Old Feb 9, 2016 | 06:01 AM
Hillsidecycle.com
Sponsor
A 107" set up correctly would work very well.
Scott
Old Feb 9, 2016 | 06:09 AM
prodrag1320
I agree
