Comp sprocket torque check
Old Oct 24, 2016 | 02:23 AM
slyedog's Avatar
slyedog
Default Comp sprocket torque check
Pulling outer primary to install heavy duty diaphragm spring. Thought whike in there I would check comp nut torque and or just replace and torque new bolt. Can I get away with removing chain and not pulling clutch hub assembly? Right now I am just @ 10k on 2012 street glide. Just being preventive. If it is not worth the effort I will let it go. thanks
Old Oct 24, 2016 | 09:50 AM
Lambda's Avatar
Lambda
If your comp isn't acting weird i would leave the nut alone, you dont need to get the clutch hub out to remove the comp
Old Oct 24, 2016 | 11:19 AM
slyedog's Avatar
slyedog
Othet than a few clunks here and there, it has never kicked back on me. Sometimes when I shut motor off I hear a little noise down there. The FSM stated to remove all ( comp, chain, clutch hub)as an assembly , and that didn't seem practical. Thanks
Old Oct 24, 2016 | 12:14 PM
Next In Line's Avatar
Next In Line
Unlike a bicycle chain, there isn't enough slack in the chain to remove only the _____ without removing the ______.
It is an all or nothing deal. No way around it without cutting the chain.
Old Oct 25, 2016 | 06:55 AM
Lambda's Avatar
Lambda
Atleast with the SE compensator I do not have to get the hub out, when you get the comp torx bolt out, the entire assembly falls off and you can remove the chain from the clutch hub, im 100% sure since I had my entire primary out two weeks ago.
Im not sure if with the first comp version you have to remove everything but something tells me that isn't needed.
Once the bolt is off, the sprocket itself can be removed from the shaft by simply pulling it out.
Old Oct 25, 2016 | 05:07 PM
slyedog's Avatar
slyedog
I'll just let it be. Not going to break the threadlock loose to add torque to it. So either i replace the bolt or let it be. Not hard to get back in there so if I start to hear a bunch of noise later I will just replace the whole damn thing. Till then no since fixing what isn't broke.
Beercan321
Mar 8, 2015 05:33 PM
ANIMAL03
Jan 6, 2010 02:09 PM
harley-jones
Dec 17, 2009 11:30 AM
Toolguy
24
Sep 13, 2009 01:12 PM
tazmandevil
Jun 20, 2008 06:34 AM
