Crankcase Removal
Old Apr 30, 2017 | 06:32 PM
jmd897's Avatar
jmd897
Got it seperated but cant lift it out. Too heavy.
Old May 1, 2017 | 03:49 PM
Imold's Avatar
Imold
I considered putting my chain hoist on it, but since it has to be swung sideways, even that would require an extra set of hands on the hoist. I was probably foolish pulling mine out by myself, throw the back out and you might drop it. And then there's all that time you won't do any more on the bike till the back heals (I've been there). If it does... Sounds like you may have to wait till you can get someone to help, keep from hurting yourself or the bike.
Old May 1, 2017 | 04:16 PM
Reindeer's Avatar
Reindeer
Removing as much as possible (cams, cylinders, stator) helps with the weight. I was able to remove mine myself fairly easily, but I'm a strapping young 40 year old (with a bad back).
Old May 1, 2017 | 06:55 PM
jmd897's Avatar
jmd897
Thanks guys. I realized i had a screw that hooks the voltage regulator cable still on. Once i took it off i was able to lift it and put it on the bench. Rookie mistake.
Old May 1, 2017 | 07:06 PM
TwiZted Biker's Avatar
TwiZted Biker
No a rookie mistake is not looking and breaking something going caveman on it , you did ok.
intrepidxc
Milwaukee Eight (M8)
13
Aug 24, 2017 06:49 PM
ninetyzero
Jun 3, 2008 09:03 AM
2007fxdc
Nov 26, 2007 02:36 PM
ftlee20723
Aug 20, 2007 04:51 PM
97fxdl
Mar 9, 2007 02:29 AM
