Fuel Moto pushrods
And you give advice?
So instead of your mis informed on going prattle that leads to this kind of banter, why don't you just show us all - please teach us you harley sensai.... please no one other than you could know anything. Wow - ya try to just help some one & other keyboard know it all commandos chime in just to have a say & talk crap.
{cough} erm... You brought it up
plus I saved some wonga for beer, why change it if you don't have to, right? as good a reason as any other I would imagine.
I never said I didn't like you; hell, I don't know you, I just read what you post. I think I can disagree with you and anyone else on this forum should I so choose. I am sure we could enjoy a beer and some BBQ anytime.
Wow, I would of thought with the components you use, the big bore jobs, cam upgrades, advice on builds, etc... you would focus on the details - well those things you mentioned I do take a little more serious & that's what separates a git r done mechanic from a sought after mechanic.
I guess when you have head work done, valves, seats, springs, etc... & do that for more power - having a PR flex at crucial RPM bands creating a form of power loss due to valve actuation being hindered is just fine? IDK - spending tons of money for HP then going with a PR that basically costs you HP is not real smart & money in the
But I guess when its not ones money they are spending - then spend away!
The angularity differences between lifters and cups or adjusting on the rocker arms can also contribute to deflection, as will the additional load caused by increasing rocker ratios or spring pressure. These angles can cause side-loading, most of which is generated at the lower end of the pushrod. Deflection can result in harmonics that often cause the pushrod to hula around and rub the block and/or heads.
Since a pushrod is longest when its perfectly straight, any change also affects length. Events of the valvetrain are carefully orchestrated to gain maximum performance, and altering the push-rod length means less lift (or erratic lift as it springs back into shape) that alters the scheduled events. The rocker will not see full travel in relation to the lobe profile, and the valve will not open correctly.
This is a "pasted" break down of what I'm talking about & said better than I could say it - this is from a speed & performance forum I am on.
Look - will most here notice PR flex "stealing" a few HP? probably not - But if you`re gonna spend big bucks on gaining HP why short yourself on a simple item for a few bucks & a little more time? the attention is in the details & to overlook those - well, its just not the way to do things.
Strangely enough - last night I'm on RT 18 in the potter twp pa area & a guy was at road side wrenching on his scoot - I stop & see if all is ok - PR tubes off & adjusting his S&S PR`s as he just did a cam chain tensioner upgrade. it just needed a little tweak as he put it - guy looked like Arnold off happy days, I stayed until he got it fired up - 10 - 15 min adjustment at roadside - nothing major - But, this is what I'm talking about some rods need adjusted even after you have it set up right in the garage or think you do?
Either way - what ever your build & whatever you do - good luck & be safe!
djl - all is good, hell a BBQ & a beer would be an awesome thing - chances are we are probably more alike than different.
