Lifters and Cam
Old May 28, 2017 | 04:56 PM
evhid1's Avatar
evhid1
Originally Posted by Tired
Just an afterthought, if you are willing to have a little headwork done and bump up the comp a bit you can make the 57's perform. This is mine at 10.2 to 1. See the torque cross 100 ft. lbs. at 1900 rpm.
I'm fighting hard not to do that, but dang, just 4 more bolts...............................
Old Jun 10, 2017 | 07:56 AM
petejoe43's Avatar
petejoe43
Originally Posted by evhid1
Yep, I thought the 57's liked a little more compression and no I am not going to pull the heads. So I will continue my search for a cam that fits my riding style. Thanks again.
I went with the Andrews 57H. This is my first cam upgrade in a 103". If you're not pulling heads it's real hard to beat IMO. I keep saying this, but it's so true. It's all in the tune. Your average tech at the dealer will struggle to get this combo right. Gotta take it to boys who tune for a living.
Old Jul 1, 2017 | 08:35 PM
evhid1's Avatar
evhid1
Default I chose the 57H with 4* Gear
I went with the 57H with 4* gear, Johnson Hylift B2313SE lifters and Smith Brother adjustable push rods. I decided not to put the Rockouts in right now and maybe do it later. I went this way because I believe I have a good MAP to start with until I can get to the independent tuner. I liked the SE204 and this way I get about the same only a little more lift. I thank everyone who took the time to give me advice and it was much appreciated. When I get this all put together I will post a report on how it runs. Thanks again.
Old Jul 18, 2017 | 07:31 AM
lionsm13's Avatar
lionsm13
Subscribed
Old Jul 22, 2017 | 06:27 PM
evhid1's Avatar
evhid1
Default Update
Update to let you all know how I like the Andrews 57H with the 4* gear in my 2012 FLHTK. I am VERY happy the way it turned out, great low in and good pull on the top. No difference in engine noise still sounds like the typical Harley sewing machine but that's fine with me. I mostly ride two up and it has all the low end I need. Great passing in 6th, at 75 MPH I am at 2800 RPM. Roll on is good. Hope this helps any body trying to decide on cams. Take care and ride safe.
doc308
Shovelhead
32
Jan 3, 2019 08:18 AM
rdc401
Engine Mechanical Topics
Jun 22, 2016 05:13 PM
adm
Feb 7, 2015 01:56 PM
Stl.glider
Jan 4, 2013 08:45 AM
O5HOG
Exhaust System Topics
Nov 15, 2005 11:04 AM
