Factory engine case plug
Old Oct 26, 2017 | 02:05 AM
captain1470's Avatar
captain1470
2nd Gear
Default Factory engine case plug
Being new to Harley I undid the factory plug on a 2015 softail .Thread still ok ..Im going to use locktite 565 and screw it back in just need some advice..Is that ok
Old Oct 26, 2017 | 03:00 AM
S.D.M.F's Avatar
S.D.M.F
Just be very careful when putting it back in, you dont want to cross-thread it or over tighten it.
Once you get it in, dont take it out again.....ever.
Get yourself a service manual and read up on how to drain Engine, Primary and Transmission fluids.
Goodluck.
Old Oct 26, 2017 | 05:30 AM
speedzter's Avatar
speedzter
Don't stress over it, there's nothing scary about the case plug.
I've lost count how many Ive pulled when checking for sumping.
I use a liquid pipe sealant. 565 or 567 will be fine.
Old Oct 26, 2017 | 05:39 AM
captain1470
2nd Gear
Thanks...
Old Oct 26, 2017 | 06:39 AM
prodrag1320's Avatar
prodrag1320
I agree,remember, use PIPE sealant,NOT threadlocker
Old Oct 26, 2017 | 06:42 AM
captain1470
2nd Gear
565 locktite I have ordered...What a stupid mistake been worry me big style..Harley Dealers worry the pants of me ..But at the end of the day it's just a thread ..
Old Oct 27, 2017 | 12:29 AM
2009blackpearle's Avatar
2009blackpearle
Default kirby
does that case plug go directly to the crankcase area through a small passage , not the oil pan area.
Old Oct 27, 2017 | 01:08 AM
captain1470
2nd Gear
Yes
Old Dec 21, 2017 | 08:53 AM
Kleenkut's Avatar
Kleenkut
Stage II
The plug you are talking about is a manufacturing plug to seal engine case from a machining process and not designed as a drain plug. However, a twin cam engine, even though it is dry sump, will always retain 6 to 8 ounces of oil in the crankcase. Over time, after many cold starts, the retained oil becomes fuel diluted and as a result this will also contaminate even fresh oil after an oil change. When i change oil, after draining the oil tank, i remove the pipe plug at bottom of right engine case to purge the fuel diluted oil from the sump as well. This is not a common service procedure. The engine should be hot when removing the plug and it will come right out. Apply thread seal compound and reinstall it to its original depth. I do this every oil change. Dont let it scare you. Just remember it is a pipe plug, install to original depth and don't over tighten.
Old Dec 21, 2017 | 01:46 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The tapered design of a pipe plug/pipe thread, is that it seals itself once tight.
Teflon pipe tape works well.
Scott
Ibfuelish
Nov 1, 2015 01:16 PM
av ultra
Sep 24, 2011 08:25 AM
Ring
Oil Archive (no new posts)
Apr 22, 2010 07:27 PM
sundancewind
Oct 26, 2007 09:46 AM
bancquo
25
Jan 24, 2006 02:11 PM
