Breather ????
Old Jan 7, 2018 | 03:32 PM
Big Dave's Avatar
Big Dave
Default Breather ????
First pic is out of 09 service manual - the rest is what i actually have
Has mine been changed or upgraded ? checked ronniesonline and all 08-09 and 10 are the same as the parts book pics
Old Jan 7, 2018 | 03:44 PM
Big Dave's Avatar
Big Dave
Ronnies shows it as the 11 up breather but i still dont have that umbrella thing , why would this be done ?
Dave
Old Jan 7, 2018 | 04:42 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Have you had the bike since new? If not some one serviced it and left it out...
Old Jan 7, 2018 | 05:06 PM
Big Dave's Avatar
Big Dave
No im second owner , I agree but cant understand why - another of lifes little mysteries LOL
When the parts get here ill put them back in , Never noticed any oil in the a/c or used any oil
Thanks
Dave
Old Jan 7, 2018 | 07:00 PM
Big Dave's Avatar
Big Dave
So seeing that little umbrella valve is like a check valve not allowing the gases back into the exhaust . Is this just a cheap way to bypass the exhaust from returning it back to the intake ?
Old Jan 7, 2018 | 07:04 PM
98hotrodfatboy
No, it's a check valve to not allow contaminants back into the crankcase. Remember these breathers are for releasing crankcase pressure. Helps to keep your gaskets and seals from leaking.
Old Jan 8, 2018 | 09:09 AM
bustert's Avatar
bustert
can you run without it??? sure, was done for decades on engines.
is it important??? well
it prevents atmospheric air back into the c/c which will reduce condensation and cleaner oil
it helps create a vacuum in the c/c which helps increase power
it helps in oil control on the piston assy
it helps oil flow as hd engines uses this diff'l pressure to move the oil from the flywheel area
awhile back, i think hd got rid of the packing since it had a tendency to clog. most of the oil is removed by the labyrinth chamber.
Old Jan 8, 2018 | 11:06 AM
hrdtail78's Avatar
hrdtail78
If the engine had external check valves (Doherty, ET, S&S....) you remove the internal ones.
Old Jan 8, 2018 | 11:37 AM
98hotrodfatboy
Old Jan 8, 2018 | 05:56 PM
Big Dave's Avatar
Big Dave
Thanks where would you look , when i purcasedthe bike it had the stock oval 96 air cleaner with stock breather bolts so im thinking there were no extrenal anything installed ???
Dave
