Permatex
Old Apr 8, 2019 | 08:53 AM
ksellers's Avatar
ksellers
Stage III
Default Permatex
Does HD use Permatex instead of real gaskets putting their engines together?
Old Apr 8, 2019 | 09:01 AM
PDB17UltraRG's Avatar
PDB17UltraRG
No way they use there specialty gaskets and will charge you out the *** for them when you need one. Permatex has its own special use never had much success using it to make or replace a gasket its a great sealer for different projects.
Old Apr 8, 2019 | 09:38 AM
J F GO's Avatar
J F GO
They use the black on the inner-primary at the rear three bolts on some models, depending on the year.
(2002 Road King, and I know this cause we just did my brothers.)
Old Apr 8, 2019 | 09:50 AM
djl's Avatar
djl
Black RTV is silicone, not Permatex. The OP is not a serious question; could be a troll.
Old Apr 8, 2019 | 10:40 AM
ksellers's Avatar
ksellers
Stage III
It's not black silicone it is between the two inner plate covers above the front drive pulley directly to the rear of the cylinder head. It appears to be hard like Permatex and not grease.
Old Apr 8, 2019 | 10:54 AM
ksellers's Avatar
ksellers
Stage III
Permatex?
Old Apr 8, 2019 | 11:10 AM
djl's Avatar
djl
HD does use a sealant between the case halves but the sealant is a material like Three Bond or Yamabond, not Permatex; however, I can't tell from the picture if that is the location you are referring to. Please post a better picture with better light and an arrow pointing to the location. Of course, it could be Permatex used by a previous owner but not by HD.
Apologies for the troll reference but the question was a curious one.
Old Apr 8, 2019 | 11:59 AM
LazySundays's Avatar
LazySundays
Permatex is a brand name, not a sealer. They make dozens, maybe hundreds, of products.
There is a sealer used between the case halves and probably in other areas of the engine as well. It's probably a type of RTV but I'd need to actually check the manual for a spec to say for sure.
Between 2 machined surfaces, like your cases, it's actually a better and more precise way to seal it than using a gasket.
Old Apr 8, 2019 | 01:28 PM
djl's Avatar
djl
The sealant HD uses is not an RTV sealant but is a sealant like Yamabond or Threebond; it might even be one of those. RTV sealant will take a hard set (exposed to oxygen) in less than 20 minutes but Yamabond/Threebond will take about 40 minutes to take a hard set. Applying sealant to prep cases for assembly is a tedious process; takes time to lay down a continuous bead, work around the case holes, avoiding letting sealant land in undesirable places, etc. 40 minutes allows the time to apply the sealant correctly and correct any errors without getting in a rush.
Old Apr 8, 2019 | 03:31 PM
LazySundays
From the HD website:
High-performance, room temperature vulcanized (RTV) silicone type liquid gasket is a low-odor, non-corrosive and non-conductive sensor-safe formula.
  • Sealant allows high elongation when cured to absorb thermal and dynamic movement of the mating surfaces
  • Resistant to most chemicals and solvents
  • Temperature Range: 76°F to 482°F (-60°C to 250°C)
  • Approved for use as crankcase sealant on all Harley-DavidsonŽ powertrains
  • Gray
  • 1.9 oz (54 g) tube
RTV is a pretty generic term. There are lots of sealers with different cure times and heat/chemical resistance that can fall into this category. As a 25+ year Ford tech, I have at least 3 different ones in my cabinet at any given times. All classified as RTV, all for different applications.
