Cam replacement questions
Old May 5, 2020 | 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Yes.
The blue, red, or brown plates and pumps are NOT needed.
Do thay look cool....sure.
We even carry them on the shelf, for those that insist.
NOT needed.
As I have said before, reminds me of the "unleaded valve seat conversions" of the Shovelhead days......
Scott
Old May 7, 2020 | 07:22 AM
ShoreRider's Avatar
ShoreRider
I'll be sure and check crank runout while I'm in there and rethink the oil pump swap! Thanks for the insgiht everyone
Old May 7, 2020 | 07:31 AM
fordhd2005's Avatar
fordhd2005
Originally Posted by Hossup
So a costly mistake as I was going through my steps I never settled the pump.
Did you by chance find all the chunks of metal from the oil pump? If not, it's going to be a very costly fix..
Old May 8, 2020 | 01:09 PM
SpiderGuard's Avatar
SpiderGuard
Hey Hossup,
Just curious about this as I just changed cams on my bike this week. Did that happen because you did not "center" the oil pump by rotating the crank while torquing the 4 bolts in sequence? I do not recall "settling" the oil pump and hope you are referring to the same thing.
Thanks
Old May 8, 2020 | 01:16 PM
GregGillette's Avatar
GregGillette
I believe that is the one and same. I infered he did not remove pump from cam plate which I also didnt do until after reading the manual, I separated to re-install using the centering bolts available online.
Derek Morrison
Engine Mechanical Topics
Dec 6, 2017 10:44 AM
Dobe66
Sep 23, 2014 10:42 AM
Rhetor
Exhaust System Topics
Jun 29, 2011 04:43 AM
jed1069
Jun 5, 2011 08:04 AM
Biker Bob
May 27, 2011 09:02 AM
