High idle. IAC problem?
Old Apr 14, 2023 | 10:02 PM
AftaDynaMint's Avatar
AftaDynaMint
Default High idle. IAC problem?
Hi. 2008 FXD is idling at start up around 2k rpm, then slows down to about 1600-1700. I had the throttle body bored to 50mm and the butterfly is definitely a tiny bit loose.
I swapped the IAC with a new fueling one. Same problem. When I put my finger over the hole in the throttle body idle doesn't change. tried it on my friends bikes and it stalls them immediately. Could this be another issue somewhere further down the line? Thanks in advance
Old Apr 15, 2023 | 07:23 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Check your throttle plate stop screw.. Back it out a little..
Old Apr 15, 2023 | 07:43 AM
bustert's Avatar
bustert
bored? did you match up the throttle plate?if not, you are getting toooooo much air by-passing the IAC.
Old Apr 15, 2023 | 08:09 AM
AftaDynaMint
I'll play with it a bit. Thanks
Old Apr 15, 2023 | 08:12 AM
AftaDynaMint
Yes. He makes the throttle plates to fit. There is a tiny bit of play though. Ill get a picture when i take it the AC off later. I think the main problem is with the IAC as I can't control the idle at all when I cover the hole with my finger
Old Apr 15, 2023 | 08:27 AM
d_slat's Avatar
d_slat
the hole you are covering is the path for the iac air. Since covering it on yours has no effect on engine speed, it proves that your problem is NOT the iac. You have too much air getting to the engine past the throttle blade or via intake leaks.
Old Apr 15, 2023 | 08:31 AM
AftaDynaMint
interesting 🤔. I've tried spraying brake cleaner cleaner everywhere on the induction module and can't get it to Rev up
Old Apr 15, 2023 | 08:34 AM
twistr's Avatar
twistr
Check the connection of the iac
Old Apr 15, 2023 | 11:29 AM
hrdtail78's Avatar
hrdtail78
Do have any tuning device that will allow you to watch IAC position? The air leak is probably your throttle blade. I would back out throttle stop until the blade is closed enough to have to have a couple of IAC control idle speed. If throttle blade is all the way closed and still has too much air. You can loosen screws and try to reset where the blade is in the bore. I'd recommend being careful and red lock tight the screws.
Old Apr 15, 2023 | 11:34 AM
nevil's Avatar
nevil
Bring it back to the shop. Since you had the throttle plate custom made to fit, I suspect it doesn't fit and you can fiddle with it all you want to no avail. Until your tech gets it right you'll be looking for a band aid.
