Dumb pushrod question
Old Jul 6, 2023 | 05:43 PM
Weeboy1's Avatar
Weeboy1
Originally Posted by djl
Sometimes it does; sometimes it doesn't; preload is not always the solution to valve train noise.
Fair enough but if I’m in there checking anyway why not kick it up a notch to .145 and see…I know you’re not keen on the feuling lifters but they are only 2 seasons in, it dynoed last year with them in and they are USA made. So I’m trusting they are not an issue…
Old Jul 6, 2023 | 07:10 PM
djl's Avatar
djl
Why not? Let us know how it turns out.
Old Jul 15, 2023 | 05:38 AM
MCRD'71's Avatar
MCRD'71
Did you let the rods bleed down long enough? I adjusted mine too quickly and had the same problem you have. Be patient.
Old Jul 15, 2023 | 08:17 AM
Weeboy1's Avatar
Weeboy1
Thanks for the reply. I was thinking about that too. I know I did between cylinders but unsure whether I waited between intake and exhaust on the same cylinder. I guess I didn’t think it was necessary as both lifters are on the base circle.
The valve train isn’t obnoxiously noisy just noticeable to me. And bike runs strong otherwise. Thought between the .131 preload and rocker lockers it would at least as quiet as before. Maybe the Andrews cams are noisy…idk (maybe I should push my earplugs further in…)
SleepyBagger
Engine Mechanical Topics
14
Dec 18, 2014 01:30 PM
73shovel rider
Mar 16, 2014 06:37 PM
sctrucker
Exhaust System Topics
19
Oct 19, 2013 06:36 AM
slyder
Jan 23, 2011 03:31 PM
jackinthebox
Dec 6, 2010 08:19 PM
