rattle on acceleration
Old Aug 30, 2023 | 08:21 AM
heritage2's Avatar
heritage2
Default rattle on acceleration
Got my 05 twin cam torn down looking for a loud rattling noise . I was suspecting the crank but when I removed the jugs and pistons there was no up or down play in the rods or no tightness in the rod bearings . I removed the outer timing chain and gears and checked the runout on the nose of the crank at the round section right behind the crank gear notch . The dial indicator shows just under .003" . Do I have to remove the cams and oil pump and check runout further in ,or should this be OK ?. The front piston was scuffed badly and seems to have a lot of piston to wall clearance . Just using a feeler gauge it has about .006" as near as I can tell . Would this cause the noise ? I have replaced lifters and gone through the valve train twice trying to cure this noise and installed rocker lockers .
Old Aug 30, 2023 | 08:36 AM
djl's Avatar
djl
Mileage? Modifications? When/how does the noise present; cold? hot?; we need more information. .006" piston to wall is a lot, particularly for stock hyper pistons.
Old Aug 30, 2023 | 09:21 AM
heritage2's Avatar
heritage2
The jugs and pistons are S&S 97 inch sidewinder kit . they were put in at about 45000 kms. the bike has 108000 kms on it now . The noise is there hot or cold . If you hold it at 2000 rpm it sounds like it is going to come apart by itself.
Old Aug 30, 2023 | 10:15 AM
t150vej's Avatar
t150vej
Yes!
Old Sep 3, 2023 | 07:39 AM
Max Headflow's Avatar
Max Headflow
This will rattle under load..
Old Sep 3, 2023 | 08:17 AM
MCRD'71's Avatar
MCRD'71
Compensator.
Old Sep 3, 2023 | 09:42 AM
Max Headflow
Originally Posted by Garage666
Compensator.
While typically TC comps in 05 models don't have any issues, it could be loose comp nut. The loose comp nut was more common on the 03s.
Old Sep 3, 2023 | 10:13 AM
WP50's Avatar
WP50
.006 Piston clearance is a bit much. I would want to address it.
But would also look at the compensator before condemning any thing else.
WP
Boxerguy8888
General Topics/Tech Tips
20
May 20, 2023 09:07 AM
barrygreen
Engine Mechanical Topics
16
Feb 11, 2018 02:17 PM
OpposedOdie
Mar 28, 2017 11:11 AM
pnw_hd_rider
Jul 16, 2011 07:50 PM
loc
Exhaust System Topics
Dec 20, 2008 04:25 PM
