Crank pin bullet proofing.
Old Mar 31, 2025 | 12:14 PM
doobaloo132's Avatar
doobaloo132
6th Gear
Default Crank pin bullet proofing.
Hello everyone,
Well about a year ago I had some bronze in my oil, checked the run out and I was at .011 The camplate, oil pump, cams and lifters are toast and I’m assuming the crank
This NOS crank ended up in my lap which I’m going to true. I’ve seen people plug and weld the ends which increases the press fit for the fly wheel. In my mind, that still relies on the press fit which can fail.
What about drilling between the pin and the wheel, pressing a dowel and tack welding? I understand the crank won’t be serviceable after this
Thoughts?
Old Mar 31, 2025 | 03:54 PM
djl's Avatar
djl
That is, by definition, "plugging" "pinning" the crank pin. Attached is a picture of a plugged and welded crank pin. IIRC, the plug is stainless and installed with a interference fit of .0045"-.006". This is a DIY project by a forum member I pulled up from a few years back. He was concerned that the heat from the TIG welding would tweak the crank out of true but it did not. He could touch the wheels after welding. I think the heavy assembly absorbed the heat like a big heat sink?
EDIT: Strike thru correction.
Old Mar 31, 2025 | 04:52 PM
98hotrodfatboy's Avatar
98hotrodfatboy
@djl
I wonder how much reciprocating mass that puts on the wheels. I imagine rebalancing would be critical..
I think the OP is referring to just pining the crank pin and welding, not plugging..
Old Mar 31, 2025 | 05:57 PM
djl's Avatar
djl
@djlI think the OP is referring to just pining the crank pin and welding, not plugging..
I think you are correct; thanks. Slip of the tongue on "plugging" vs "pinning"; they are two different procedures; my bad. I need to edit my post to be clear.
Old Mar 31, 2025 | 06:16 PM
98hotrodfatboy
Originally Posted by doobaloo132
Hello everyone,
Thoughts?
I'm not a machinist but I would imagine two very high carbon steel pins (heat treated) with a tight press fit and at least a 1/4" weld, 2 on each wheel will help.. I would think the hard part would be trueing..
Old Mar 31, 2025 | 09:44 PM
doobaloo132
6th Gear
Originally Posted by djl;[url=tel:21984002
21984002[/url]]That is, by definition, "plugging" "pinning" the crank pin. Attached is a picture of a plugged and welded crank pin. IIRC, the plug is stainless and installed with a interference fit of .0045"-.006". This is a DIY project by a forum member I pulled up from a few years back. He was concerned that the heat from the TIG welding would tweak the crank out of true but it did not. He could touch the wheels after welding. I think the heavy assembly absorbed the heat like a big heat sink?
I saw this post and it’s what gave me motivation to give it a go. I’m going to plug mine like this but I didn’t know if putting a pin in there as well would be beneficial.
Old Mar 31, 2025 | 09:46 PM
doobaloo132
6th Gear
Originally Posted by 98hotrodfatboy;[url=tel:21984050
21984050[/url]]@djl
Good point. Those pins don’t weigh much but it does add a little mass. I was planning on plugging the crank as well but maybe this is a better alternative? Just curious if anyone has done it this way.
Old Apr 1, 2025 | 08:34 AM
bustert's Avatar
bustert
do you stress the machine?
if normal rider, all of that is moot.
i do say this, be careful doing anything to the crank, they are not a piece of non destructible steel and in a way fragile. stress induce fracturing is a possibility.
i doubt that small welds will affect the balance that much, where it is more important is the piston assy.
on diff machines, sometimes a small hole is drilled and tapped and a allen is thread locked between the matting surface.
not dragging??? spend the money on beer. how many stock cranks are there merrily spinning on over the decades living happily ever after. shoot i ran 170+k miles on one and only went to s&s because bird in hand, had the engine out for frame restoration and upped the ponies.
Old Apr 1, 2025 | 08:47 AM
98hotrodfatboy
On my well built stock crank 110"er there has been no run out change in 13k miles. Yes, I measured it because I do a lot of cam changes looking for more power. For now I' back down to my Stage II heads with a TW-888 @11.16:1 comp.. No issues.
SledKicker
Panhead
May 15, 2024 09:26 AM
Salmo pass
Engine Mechanical Topics
Mar 4, 2019 03:17 PM
VETERAN75
Mar 3, 2014 01:57 AM
rkduq20
Jun 2, 2013 04:20 PM
Bill C
Exhaust System Topics
Mar 23, 2009 03:53 PM
