Oil Pump issues
Old Sep 5, 2025 | 07:50 PM
Harleyonthebrain's Avatar
Harleyonthebrain
Default Oil Pump issues
A friend bought a 03 Softail with low miles 25,000 . Said it was making noise. Ik started it and front lifters were loud. So I changed them. Which I've changed some before. It was ok sounded good the next day I fired it up and they got loud again but this time the oil light came in and stayed on. We thought maybe the tensioners were getting bad so I had a look they didn't look to bad but I installed a s.e cam plate upgrade high volume pump and hydraulic tensioners new rear lifters as I had just replaced the front and also adjustable push rods. As I have installed a few of these kits before. And yes I did rotate the rear wheel in 5th gear to make sure the oil pump was centered and torqued the 2 bolts while rotating as per directions. Well the lifters are still loud and the oil light is still on. I also made sure oil holes in lifters were pointing towards holes in case front and rear. I also pulled the oil pressure switch and ran it for a minute and there was oil coming out. Although seems like the oil return to the tank is real slow like it's just spitting some every little a while.So I'm open to any and all suggestions anyone may have. Like I said I've installed a few of these kits and have never had any problems like this . So thanks in advance. I'm hoping someone has some good advice as to what and where to start looking at.
Old Sep 5, 2025 | 08:49 PM
Ed Ramberger's Avatar
Ed Ramberger
What is the oil pressure using a mechanical gauge?
Old Sep 6, 2025 | 07:49 AM
Harleyonthebrain
I'm not sure I don't have a mechanical gauge.
Old Sep 6, 2025 | 08:20 AM
Rounders's Avatar
Rounders
Gauge is best way to check. But new lifters loud is interesting. If you replaced the cam plate, then plunger should be operating fine
Lot to read in your post. At bottom stating everything you replaced and what symptoms are still there might not hurt
Old Sep 6, 2025 | 01:16 PM
marcodarq's Avatar
marcodarq
did you replace the oil and filter during your work?
m
Old Sep 7, 2025 | 07:52 AM
Harleyonthebrain
So I installed the new S.E Camplate upgrade with high flow oil pump hydraulic tensioners and new stock hd lifters and S.E adjustable pushrods. I did not change oil and filter as it was new.
Old Sep 7, 2025 | 08:01 AM
Rounders's Avatar
Rounders
Unless you had debris from failed part, I would not have changed oil either
Old Sep 9, 2025 | 02:50 PM
Harleyonthebrain
Default Oil pump
So idk but I went through pushrod adjustment again blew the oils lines out and I did change the oil as my friend said he'd used some oil from tractor supply that I've never heard of . Fired it up and oil light is off and lifters are quiet and good to go
noriderz
Oil Archive (no new posts)
Dec 7, 2022 06:18 PM
splittie65
EVO
107
Jun 1, 2022 09:02 AM
f4dennis
Engine Mechanical Topics
25
May 27, 2014 10:10 AM
Robtarra39
Jul 2, 2013 10:56 AM
asm481
Apr 11, 2010 07:29 PM
