98 flhtc ignition switch removal without key?
Old May 29, 2015 | 01:03 PM
Spatenkopf's Avatar
Spatenkopf
Stage II
Default 98 flhtc ignition switch removal without key?
Hey all,
tumbler went bad, key slot is stuck between lock and unlock. Had to use channel locks on the big **** to turn it to start bike, but still can't get key in to lock or unlock it.
That means, I can't take the ignition off since manual and forums all say you need to key to take off the **** while depressing the tab underneath.
I'm loathe to attempt to take the *** off without the key. I could just forget about it now that I can turn the bike on at least, but do like the ability to lock it as a discouragement to theft.
I have searched all the forums and even my mechanic is scratching his head short of using a dremel to cut the **** off but said will have trouble.
Thanks
CB
Old May 29, 2015 | 02:01 PM
Beemervet's Avatar
Beemervet
There is a recall on '98 FL switches. You may want to see if yours was done and if it is still an active recall.
Old May 29, 2015 | 04:41 PM
Spatenkopf's Avatar
Spatenkopf
Stage II
Recall done in 99. Mech stumped on how to get it off without key
Old May 29, 2015 | 05:38 PM
bagga's Avatar
bagga
did you try a few drops of oil? i lubricate my switch and locks every year.
Old May 29, 2015 | 05:46 PM
jmn1960's Avatar
jmn1960
if I recall (when I broke mine) that the top of the switch where the nut goes on is plastic ,, so you should have no problem snapping it in two , then just order a switch with keys as the replacement come w/o keys and tumbler
Old May 29, 2015 | 07:45 PM
Beemervet's Avatar
Beemervet
I may or may not have heard that there exists on utube a video showing how to pick a barrel lock using part of a ball point pen.
Old May 30, 2015 | 12:25 PM
larsfum's Avatar
larsfum
If the slot is stuck between lock and unlock you can file off the tab on a key and then slide it in the barrel lock.
rmurry
Aug 8, 2018 12:00 AM
Speleo
Jul 20, 2016 12:55 AM
pseudolus
Jun 7, 2011 12:21 AM
gnafin
EVO
Nov 1, 2009 09:22 AM
shawn e.
Oct 4, 2008 04:15 PM
