Where does battery ground on a 95 Classic?!?!
Old Jul 8, 2015 | 08:13 PM
Josh Barto's Avatar
Josh Barto
Stage I
Default Where does battery ground on a 95 Classic?!?!
Had a buddy pull starter out for me, as I'm putting it back in I'm seeing my battery ground lead and frame ground lead loose from somewhere. Where do they go?
Old Jul 9, 2015 | 02:01 PM
IBDAGRIZ's Avatar
IBDAGRIZ
In case you are still looking it is usually on one of the bolts for the starter that holds it onto the inner primary.
Some are attached above the starter near the battery area of the frame. If you have two grounds going somewhere, and one of them is from the frame ground bolt, then my guess is the starter bolts.
Griz
Old Jul 11, 2015 | 06:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
An Electra Glide Classic, a Heritage Softail Classic?
Old Jul 11, 2015 | 06:30 AM
bagga's Avatar
bagga
my 85 has the ground attached with the bolts holding the starter to the inner primary.
Old Jul 11, 2015 | 08:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Ya think we will ever hear from the OP again?
Old Jul 11, 2015 | 08:59 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It's only been 4 days since he posted.
I guess he isn't in a rush to fix it.
Old Jul 11, 2015 | 09:10 AM
Uncle Larry's Avatar
Uncle Larry
Hopefully he "followed" the cable to the other end ???
Old Jul 14, 2015 | 04:39 PM
D4rkn3ss's Avatar
D4rkn3ss
On my '95 FLHT it grounds to the starter
Bagger99
Apr 24, 2013 11:46 PM
twincaman
Exhaust System Topics
Mar 21, 2013 01:04 PM
sportyguy69
Oct 23, 2011 03:06 PM
Sling72
Aug 29, 2010 02:16 PM
84sugar
EVO
Mar 23, 2008 11:46 PM
