My first break down, sorta.
Old Nov 16, 2015 | 03:49 PM
  #51
junglejoe's Avatar
junglejoe
Originally Posted by Dr.Hess
The kill switch is in the Run position, right? Sorry, it's come up before.
Get a schematic for your bike and start following the wires. As mentioned, the white wire at the coil should have power. It gets it from the kill switch, which gets it from the ignition switch, which gets it from the battery. There's some breakers and/or fuses inbetween.
Well chit Dr., I assume I had it on 'run" dammit... lol Now Now you have me wondering.. I took the ignition module off checking wires.. Ill put it back together and see...
Old Nov 16, 2015 | 03:57 PM
  #52
Joe_G's Avatar
Joe_G
My bike won't crank if the switch isn't in the run position. I think my 95 Evo was the same but can't swear to it.
But that said, if your white wire to your ignition module has no power, trace it back and see why not. That's your problem, your ignition has no power to it.
  #53
junglejoe's Avatar
junglejoe
I have power to everything but that hot wire... fuses are all good too!
Attached Thumbnails My first break down, sorta.-.jpeg   My first break down, sorta.-.jpeg
Old Nov 16, 2015 | 03:58 PM
  #54
Joe_G's Avatar
Joe_G
Trace that white wire back and figure out why it doesn't have power.
Old Nov 16, 2015 | 04:00 PM
  #55
junglejoe's Avatar
junglejoe
I'll report back in a little bit.. going out in the garage and put it back together and make sure I have the on/off switch on.. I'm pretty sure I did, but..
Old Nov 16, 2015 | 04:10 PM
  #56
Schex's Avatar
Schex
I thought you tried the jumper wire back in post #20
Old Nov 16, 2015 | 04:12 PM
  #57
junglejoe's Avatar
junglejoe
Ok.. we have power!! CHIT!! My brain is tired from tracing wires.. BUT, with the kill switch on.. coil has power. So, I guess need to figure out why the red LED light isn't coming on on the ignition modual..
Old Nov 16, 2015 | 04:13 PM
  #58
junglejoe's Avatar
junglejoe
I did that too Schex3x.. but I guess I didn't have the kill switch on.. however, we have fire on the coil wire...
Old Nov 16, 2015 | 04:18 PM
  #59
Joe_G's Avatar
Joe_G
What about the white wire to the ignition module?
Schex3x he can put power to the coil but without the signal from the ignition module the coil is not going to fire.
Joe you could install points again if you want..lol
If you want to jumper a wire jumper a feed to the white wire. But you eventually need to figure out why that white wire doesn't have power so trace it back.
Old Nov 16, 2015 | 04:25 PM
  #60
junglejoe's Avatar
junglejoe
SOB!! it fired right up!! I might be a retard! LMAO.. Don't tell me I didn't turn the kill switch on this whole time!!??
