Throttle Cable Issues
Old Dec 18, 2015 | 10:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
IF you go to your nearest pharmacy and buy the biggest syringes they have then put the cable life into the syringe you can lube the cables from the top.
In other words just take the top switch housing off.
Stick the needle of the syringe into the top of the cable.
Depress plunger.
That way you can lube the whole cable.
The way the guy in the video does it he misses the top metal part with the 90° bend in it.
Old Dec 18, 2015 | 12:58 PM
Uncle G.'s Avatar
Uncle G.
Before you do any of this, check to make sure your throttle lock (star shaped screw underneath the throttle housing) isn't engaged and partially locking the throttle grip.
Old Dec 19, 2015 | 06:03 PM
Ozark Joe's Avatar
Ozark Joe
Good news is I found what was causing the prob. After spraying PB Blaster (thats all i had on hand) down the cables,I look at them from the carb end. I finally noticed that the jacket that covered one of the cable has pop out of socket(after I broke down and used a flashlight on it).
Bad news is that the cable has been frayed. So I'm looking at a replacement in the near future.
For now I have to figure how to pop that jacket back into place.
Old Dec 19, 2015 | 06:23 PM
texashillcountry
Dirt don't hurt
What socket?
Old Dec 19, 2015 | 07:48 PM
Ozark Joe's Avatar
Ozark Joe
Here what the frayed cable looks like
Old Dec 19, 2015 | 09:31 PM
apples402's Avatar
apples402
unless I am seeing this wrong I believe that both cables are out of their sets. I think the pull cable (the one still hooked up) goes in the notch above it and the loose one goes into a notched area further back on that same bracket.
Old Dec 19, 2015 | 11:00 PM
Owtlaw's Avatar
Owtlaw
Yeah, they're not even close to correct,
Old Dec 20, 2015 | 07:33 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to be looking at replacement in the very near future, as in....immediately
Old Dec 20, 2015 | 09:07 AM
texashillcountry
Dirt don't hurt
Khibbs
Apr 15, 2018 02:56 PM
zachpeed
Mar 2, 2014 10:32 PM
KDagostino
Apr 8, 2013 08:44 PM
Midgard
Aug 21, 2012 02:25 PM
HDF Tech
Jul 18, 2005 12:22 AM
