EVO Rebuild
Old Jun 3, 2018 | 09:34 PM
  #31
Kingglide549's Avatar
Kingglide549
That lean number for sure needs to away.
That is why I like my own AFR on the handlebar, I can see what is going on , now.
Old Jun 3, 2018 | 10:30 PM
  #32
Tommy C's Avatar
Tommy C
What are you using for exhaust, OP? If you still have those chimney pipes on those are horsepower killers right there.
Old Jun 4, 2018 | 11:46 AM
  #33
Daedalus's Avatar
Daedalus
True that. I ditched my V&C chimneys for the same reason.
Old Jun 4, 2018 | 08:53 PM
  #34
Tony_N's Avatar
Tony_N
Originally Posted by 1997bagger
Mikuni is a little crisper and hits harder but it's a lot of money like the tuner said.
Next question, did the tuner feel it was acceptable to have WOT AFR's peek at 12.5 and fall off to 10.0? a carb is a prehistoric metering device but can still hold better numbers than this run, you have power left on the table. I've ran both a modded CV and Mikuni 45 on the same engine with a digital AFR reader and both could hold a consistent AFR during a WOT when dialed in.
Something else is a 16.0 on the throttle wack, that is in detonation area, need to get the bike to someone who is going to tune it using the good equipment unless this was just a numbers run, either way you have work to do addressing probable detonation area especially in Summer temps and the back end flood.
Thanks Bagger! After the rebuild I told the original builder that I wanted a dyno tune and the AFR checked. His reply was "no one can read a plug better than me". One of many reasons I won't be returning.
I will get back with the shop that ran the dyno tune and work to get the AFR dialed in. He did tell me the throttle response wasn't great. Also look at a better pipe for the hp.
Yeah Tommy C...I'm still running the Rush 6022 ST. Guess I need to rethink those too.
lunatikfringe
EVO
Apr 30, 2017 09:50 AM
skypilot_one
Milwaukee Eight (M8)
23
Nov 7, 2016 06:06 AM
SmittyFXDL
Apr 22, 2014 09:25 PM
drc1279
Exhaust System Topics
Jun 8, 2013 05:25 AM
PakMul
Sep 29, 2010 09:27 AM
