front brake lines
Old Sep 24, 2016 | 07:51 PM
dports70's Avatar
dports70
Default front brake lines
so over the weekend i put some new bars on my ultra classic, the stock bars where horrible
took the time to do everything nice and neat, internal wired all 24 wires, yes it was a huge pia, but looks nice and clear, the only problem is the damn hard front brake line that is 1 piece top to calipers ( straigtened it to make it work for now unti i can find an alternative ) , so my question is is it possible to upgrade the front brake lines to the one's on 96-07? as the line to the master is a soft line and will look so much cleaner, this is the style im talking about, but will probably go braided stainless, for the looks.. thanks as always you guys are great
http://www.ebay.com/itm/DS-Vinyl-Bra...-/331969068122
as you can see the front brake line is horrible
Old Sep 24, 2016 | 08:19 PM
MURPHCC1's Avatar
MURPHCC1
zip tie it to the handle bars.....
Old Sep 24, 2016 | 08:23 PM
MURPHCC1's Avatar
MURPHCC1
run them down the bars......looks ok.
Old Sep 24, 2016 | 08:27 PM
dports70's Avatar
dports70
i would if it wasn't a metal hard line, see the front brake master cylinder line from the master is a rigid line until it gets inside fairing then it has about 6" of rubber, then rigid again until under the fork, where it splits to caipers
Old Sep 24, 2016 | 08:38 PM
Crashone's Avatar
Crashone
If the banjo bolt opening/ fitting is the same size on both lines where it connects to the master cylinder it should work.
Old Sep 24, 2016 | 10:12 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
When I went to dual disk I bought aftermarket braided flexible brake lines and fittings.
Old Sep 25, 2016 | 05:30 AM
grbrown's Avatar
grbrown
Lightbulb
Just throw the entire front brake pipe set in the bin and buy a braided set. Sorted!
Old Sep 25, 2016 | 06:17 PM
dports70's Avatar
dports70
plan on it why i asked about 96 - 07 lines, they are flex vs rigid
Seaplane-883
Apr 13, 2013 07:31 AM
GeorgeJ
Apr 10, 2013 02:35 PM
jlilnc14
May 20, 2012 02:05 PM
coz300
Jan 3, 2012 07:04 PM
Rowdy25
Nov 15, 2007 11:15 PM
