Awwwww man!
Old Apr 22, 2017 | 11:19 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by flhchaz
I ordered it off Ebay. Here is a link to a similar one:
http://www.ebay.com/itm/131342899478...%3AMEBIDX%3AIT
Thanks.
That one says 6-13mm.
Do they make a different one for standard size bolts or does it matter?
Old Apr 22, 2017 | 11:38 AM
flhchaz's Avatar
flhchaz
It really doesn't matter. It works similar to a chuck in a drill press, the 3 parts on the inside have teeth on them. It slides over the stud, as you turn the nut on the back of the tool counter clock wise, it tightens onto the stud. A 3/8 ratchet fits into the nut on the back, the harder you turn to loosen the stud the tighter it grips the stud.
I ended up taking both studs out as the kit from colony has 2 new ones. I heated the first stud with a propane torch for about 30 seconds and it came right out. I removed the second stud with out any additional heat. I think it listed in millimeters because that seller is in the UK.
Old Apr 22, 2017 | 12:57 PM
Beemervet's Avatar
Beemervet
There is no substitute for the proper tool for the job.
Congrats (and I just may have to add that to my toolbox)
Old Apr 22, 2017 | 12:58 PM
flhchaz's Avatar
flhchaz
So much better than effing around with vise grips!
Old Apr 22, 2017 | 01:38 PM
row jimmie's Avatar
row jimmie
Left handed drill bit works on flush twisted off bolts and ones stricken out.
0maha's Avatar
0maha
Love reading about a successful outcome!
Old Apr 22, 2017 | 01:51 PM
texashillcountry
Dirt don't hurt
I was thinking the same thing.
Old Apr 22, 2017 | 02:57 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yes it does.... Used it many times throughout my career....
Speleo
Jan 30, 2015 06:02 PM
tjcaron
Dec 28, 2013 05:11 PM
toecat2000
Feb 18, 2011 07:19 PM
mang0
Oct 6, 2010 04:34 AM
mang0
Wheels/Tires
Oct 3, 2010 07:01 PM
