Can change question
Old Jan 1, 2018 | 07:49 PM
Calwoodbutcher's Avatar
Calwoodbutcher
Default Can change question
Changing out stock can to ev27. Old cam came out with the cover. Now I cannot line up timing marks before removal. Top end and lifters are off so no problem turning the beast over. Pinion gear looks to turn twice to the cams once. Need some help here please. Don't want to line them up on wrong rotation.
Old Jan 1, 2018 | 07:53 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Believe it or not you can't line the marks up wrong.
If you match up the marks on all 3 gears you will be fine.
Old Jan 1, 2018 | 08:02 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you had a FSM I don't think you would be asking this question....
Old Jan 2, 2018 | 07:54 AM
Calwoodbutcher
Gots an FSM and a Clymers to boot. Read them both. That does not stop the little gremlins in my head from overthinking things. That is what the internet if for son.
Thanks for the answer Tex.
Old Jan 4, 2018 | 12:26 PM
Uncle G.'s Avatar
Uncle G.
Tex is right about this. There's only one way the marks on all three gears will line up. That said, I've been known to take a picture of the timing marks aligned, just before buttoning up the motor. It helps ease my mind, having proof that I did it right. sort of like wondering if I turned off the stove before leaving the house.
Old Jan 4, 2018 | 12:53 PM
98hotrodfatboy
Not your son and it's all in the FSM... Stop overthinking.........
Old Jan 4, 2018 | 04:07 PM
Calwoodbutcher
Don't take offense. I am 65 and have a habit of calling everyone son.
Old Jan 6, 2018 | 09:40 AM
WP50's Avatar
WP50
Tex nailed it as said.
One thing I'll mention. Stick with the FSM for info. Some info can be troublesome to find in it BUT it's all there.
Have seen folks get confused switching back and forth between FSM and aftermarket manuals. Terminology, wiring and pictures come to mind first.
I can overthink on new stuff all to well myself.
WP
Little Mike
Oct 18, 2016 06:36 PM
95ci springer
Mar 1, 2016 01:57 AM
heavyd460
Jan 3, 2013 10:04 AM
carltex
Jan 31, 2011 09:49 PM
mjd98
EVO
32
Mar 20, 2010 11:12 AM
