oil pump help please
Old Jun 3, 2018 | 08:01 AM
  #61
Dazzauk's Avatar
Dazzauk
Originally Posted by johnjzjz
remember the oil take if not cleaned and new oil hoses can have more of the same that went through the oil pump a magnet wont do it
it needs to be scrubbed clean
yeah I plan on going through it very thoroughly I don’t want to be in this boat again.
daz
Old Jun 3, 2018 | 09:08 AM
  #62
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Dazzauk
Hey guys, whats up,
So the disassembly has begin, made a good start, im in no rush,
i would like to ask if someone could run through a quick step by step on clutch and compensator removal? Im not sure if i need a spring compressor tool for the clutch , Obviously i want to make sure i do this correctly, so better to ask than to just get at it lol
I have the factory service manual , however i am finding it a little cryptic.. Heres what it says....
Also would like someone to look at my chain adjuster, it looks like somebody has cut up some square plate washers, im not sure this is correct, or did somebody bodge this?
Daz
As mentioned you need a 1 1/2" socket for the compensator and a 1 3/16" socket for the clutch hub (left hand thread).
You won't need the spring compressor but you will need some snap ring pliers to get that clutch adjuster plate off.
Your chain adjuster is a Hayden M6.
Old Jun 3, 2018 | 01:43 PM
  #63
Dazzauk's Avatar
Dazzauk
hey texashill
so my chain adjuster is suppose to look like this? With these shins?
all off and out now. I think I’ll grab a pic of the chain adjuster tomorrow and see if you guys think it’s worn?
daz
Old Jun 3, 2018 | 02:41 PM
  #64
Kingglide549's Avatar
Kingglide549
I for get which bike that is
Evo?
If so, No that's some aftermarket junk..
Old Jun 3, 2018 | 02:46 PM
  #65
Dazzauk's Avatar
Dazzauk
Evo?
1996 dyna wide glide.
Old Jun 3, 2018 | 07:47 PM
  #66
texashillcountry
Dirt don't hurt
hey texashill
daz
What you have is a Hayden M6 it's an aftermarket automatic chain tensioner.
The shims are how you adjust chain tension.
As for your shoe how deep are the grooves in it?
If they are deep get a new shoe and if they are light or not there then just put that one back in.
Old Jun 7, 2018 | 01:10 PM
  #67
Dazzauk's Avatar
Dazzauk
Hey guys,
so engines almost most ready for removal, I think all that’s left to do is unbolt it and somehow lift it out lol.
Then it it will be time to strip here down and see what’s what.
A few few questions I have if anyone has any experience I noticed a few things whilst stripping down what I have so far so....
2 plastic spacer type things inside primary? The went between outer and inner they looked knackered anyone have any idea? Pics enclosed
stator has very small amounts of metal on it stuck to the magnets is this normal?
on the inner primary on the face which sits against the engine. There is some kind of light sealant around the cut out?? There is a o ring on the engine side which makes sense but he sealant??
thats as far as I’ve got so far chaps
daz
Old Jun 7, 2018 | 01:35 PM
  #68
Kingglide549
Oil tight gaskets so oil does not leak ou the back side
Old Jun 7, 2018 | 02:12 PM
  #69
Dazzauk's Avatar
Dazzauk
you can buy these right boss?
Old Jun 7, 2018 | 02:46 PM
  #70
Kingglide549
Most people I know just insert their favorite thread sealer.
If you have the back of the primary off epoxy the holes.
PS- I am sure you can buy them or make them too
