5spd lock up
Old Jun 5, 2018 | 10:47 AM
brad75raiders's Avatar
brad75raiders
Default 5spd lock up
Yesterday headed into work late. So I grab my trusty FXR. Haul *** get there on time. Couple of 100mph shift on the back roads kinda fast.after my 16 hr shift I go out to leave everything seems normal. Bike fired up sounds great. I take off down the road no problems. Come to a stop by using the front and rear brakes as well as down shifting. I take off first then second 25-35 mph then my rear tire locks up.
so bike is in third clutch in motor is running. If I let the clutch out the bike will die so I cut the ignition off. I can barely Rock the bike back and forth. After a few min the lock up let's go. I am able to put it back in neutral start up shifts into 1st and limp back to work. I am thinking trans because I recently adjusted my shifter pawl but had no problems going to work. ....... What do you guys thunk.
Old Jun 5, 2018 | 11:25 AM
Daedalus's Avatar
Daedalus
Sounds like the trans is in 2 gears. Had it once on a truck that broke a shifting fork, never heard this happens to motorcycles as well. Especially the release after a few minutes is weird.
Old Jun 5, 2018 | 02:52 PM
55 Pan's Avatar
55 Pan
yup agreed with what he said above.
you adjusted it too far** and caused, and or..the shifter forks are bent with what he said locking them between two gears.
Old Jun 5, 2018 | 03:50 PM
brad75raiders
Ok thanks you guys I will pull the covers off and take a peek
Old Jun 5, 2018 | 07:37 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Glad to hear you didn't lose it on the lock up. Definitely sounds like it was into gears simultaneously I would check your shift drum make sure that's all tight and check the dogs on the shift Forks where they go into the shift drum you might have broken one. almost what it sounds like
Old Jun 6, 2018 | 01:46 PM
brad75raiders
Mother ****ing trans dip stick broke off. WTF
Old Jun 6, 2018 | 02:50 PM
Daedalus's Avatar
Daedalus
Uh oh... I don't think gears like these
Have you got the cover off?
Old Jun 6, 2018 | 06:21 PM
johnjzjz's Avatar
johnjzjz
all the metal is in the door bearings
Old Jun 6, 2018 | 07:26 PM
brad75raiders
Luckily it was still in big pieces
Old Jun 6, 2018 | 09:21 PM
Mattbastard's Avatar
Mattbastard
Holy ****! Guess the engineers never took that into account on the design of it.
Warranty?
