Fuse box
Old Feb 25, 2019 | 10:44 AM
grbrown's Avatar
grbrown
You don't have a fuse box - nor a service manual, by the sound of it! If your wiring is original you only have circuit breakers and from what you describe they haven't interrupted anything.
Start with say the headlamp and carefully check through the wiring, connectors, ground points etc, check wires for damage, chafing etc, pull apart any connectors, clean and coat with dialectric grease. Repeat on each of the other light circuits. This sounds like something a bit obscure, so you need to draw on your inner Sherlock Holmes!
gartec81
Feb 22, 2016 01:43 AM
pretz
Sep 24, 2015 10:08 AM
75hdxlh1000
Ironhead
May 7, 2013 01:19 PM
nichols292
May 28, 2012 09:32 PM
cmose
Mar 24, 2012 03:40 PM
