Help with a stalling problem
Old Aug 14, 2019 | 06:06 AM
  #71
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Kabear
Try replacing the advance weight springs with a set of less tension, then adjust your timing back a few degrees. This will allow the engine to start easier then give you full advance at a lower RPM. It will move the advance curve back to a lower RPM.
Also get in touch with S&S and make sure you are using the correct timing marks for the correct cylinder. It is my understanding that these can differ from engine to engine, there will likely be someone here that actually knows the answer to this.
Although I do not have a new 111 I have done some research on it and also spoke with THC about his.... The way that I understand it is that the way S&S has you set the timing it actually puts you at 40* when at full advance.. Not a 100% sure but I would definitely give them a call and tell them what's going on... It's possible that this motor requires their ignition module...
Old Aug 26, 2019 | 07:18 PM
  #72
misfitJason's Avatar
misfitJason
New advance at the house. Going to install tonight. A really nice one if any of you guys need a replacement in the future. American prime manufacturing.
If this doesn't fix it I'll be switching to a full electronic ignition. Either Dyna 2000i or a Daytona Twin Tec. Funnily enough I was watching videos on the two ignitions and came across this video.
It explains the difference between dual fire and single fire. I am running a dual fire now. The video talks about dual fire sometimes giving a carb cough igniting the fill in the cylinder. This sounds exactly like what I am experiencing. Never thought about it.
Old Aug 26, 2019 | 07:30 PM
  #73
98hotrodfatboy
The compufire ignition I sent you is a single fire, you just need to get a single fire coil.. 3 ohm.
Old Aug 26, 2019 | 07:55 PM
  #74
misfitJason
I sent it back. If I am going to change a whole ignition I am just going to buy a full kit and start fresh rather than buying a coil and then possibly changing ignitions anyway.
Should be back to you today or tomorrow hot rod. Thanks again for the loaner parts!
Old Aug 26, 2019 | 08:00 PM
  #75
98hotrodfatboy
Anytime.... Yw...
Old Aug 30, 2019 | 11:11 AM
  #76
misfitJason
Replaced the advance with the new one. SHe runs really good now but still does the intermittent stall. Spent some time on the phone with Daytona Twin tec and all things point to the dual fire ignition being the issue. Looks like I might finally have a resolution
Old Aug 30, 2019 | 12:17 PM
  #77
RANGER73's Avatar
RANGER73
I really want to know how this turns out.
I did a cam change over the winter on my 94 Softail.
Andrews 27, S&S Quickie Pushrods, lifters, and an S&S ignition
I was getting backfire on deceleration, replaced the manifold gaskets, no change.
I had to turn out the idle screw and turn up the idle to 1000-1100.
Old Oct 10, 2019 | 01:34 PM
  #78
misfitJason
The new advance didn't make it go away. Here is a video of it still doing it. I am going to order a new ignition after biketoberfest. Until then I have just been riding her
Old Oct 10, 2019 | 06:33 PM
  #79
98hotrodfatboy
So at the 48 second Mark it just stalled? The way it stalled would not indicate a fuel issue nor a vacuum leak of some sort. If that was the case it would run rough then die... it's idling perfect before it quickly stalls which is telling me it's electrical.
Do you have a breaker for the ignition module and coil..? Are they on they on the same circuit? If so I would take a new breaker 15a, wire it directly to the battery and a new wire to the coil and also a wire to feed the ignition module to help eliminate a wiring issue. Another test tool you can make is sort like a test light. Take a12v bulb and Wire it directly to the positive side of the coil and the other wire to ground, it should light and stay lit. monitor it while the bike is running.. if the light goes out when it stalls.. your positive feed to the ignition system has an intermittent connection issue.. I would confirm though that both the ignition module and coil are wired from the same circuit...
Old Oct 12, 2019 | 12:17 PM
  #80
hdbob2006's Avatar
hdbob2006
Yes water works great for cleaning the carbon off the valves,The runners, ports etc. Thing is, it's a brand new motor AND there is no way to get water into the Jets...
Unless you put the water in the gas tank!
