Never had this before
Old Jun 29, 2019 | 05:12 PM
Hey Man's Avatar
Hey Man
Default Never had this before
I have oil seeping out from under the washer behind the nut on the case bolt. I know it may appear to be coming from the rear base gasket but it is not. I've cleaned the area, run the motor and can see when it starts to weep from under the washer. Two questions please. A. What horrors will befall me if I loosen that nut, clean the area and install a new washer with some sealant? B. Is there a special tool to remove the oil pressure switch or will a 12pt. socket get it?
Old Jun 29, 2019 | 05:23 PM
Jackie Paper's Avatar
Jackie Paper
See it many of times on here. I would torque it tight before i tried removing it.
Old Jun 29, 2019 | 05:34 PM
TwiZted Biker's Avatar
TwiZted Biker
Pull the nut & washer on both sides, clean & degrease well, smear a little Hylomar on the threads and back of the washer install & torque. Use a little brake clean or rubbing alcohol on a rag to clean any excess. Fixed many a case stud seep this way in frame.
Old Jun 29, 2019 | 07:06 PM
t150vej's Avatar
t150vej
Yeah mine did that after the last time I split the cases. I got too stingy with the RTV I reckon. No problem taking it loose - won't hurt anything. Just do it when it's cold engine and torque it back to 25 ft/lbs.
I tried all the aforementioned tricks and ended up a copper washer but still get a slight oil stain on my natural cases after a long ride. They now have bonded sealing washers in all sizes. I never knew they made such a thing till I got that last top end gasket set from HD about 10 years ago. I'm gonna put one of those on it one of these afternoons.
Old Jun 29, 2019 | 08:38 PM
carlgrover's Avatar
carlgrover
I didn't use anything special to install my oil pressure switch but I did break it when I overtightened it.
carl
Old Jun 29, 2019 | 10:51 PM
Yankee Dog's Avatar
Yankee Dog
Do this! If you can’t find hylomar, use permatex 85420 permashield fuel resistant gasket dressing and sealant. Can get it at autozone or orielly. It’s pretty much the same stuff as hylomar. It’s good stuff! Never gets hard like silicone. YD
Old Jun 30, 2019 | 12:32 AM
Hey Man's Avatar
Hey Man
Thanks for all the suggestions. That'll be my project for Monday.
Old Jul 1, 2019 | 05:47 PM
Hey Man's Avatar
Hey Man
So, it is done. Was so easy I didn't even have to remove the oil pressure switch. Already had the Permatex so I went that route. I'll pick up a few of those bonded sealing washers in case the fix fails. I'll only put one on the nut side though cuz I'd have remove the whole primary to get that long bolt out and that AIN"T gonna happen.
Thanks again.
Adrian Vasquez
General Topics/Tech Tips
Feb 19, 2019 08:37 AM
batch
EVO
26
Dec 9, 2012 10:58 PM
SPARKY01
Apr 2, 2009 11:31 AM
scottperry00
Oil Archive (no new posts)
Dec 19, 2008 12:47 PM
DPete
Sep 7, 2008 07:07 PM
