Speedo
Old Nov 20, 2019 | 12:41 PM
evotrike's Avatar
evotrike
Default Speedo
Anyone know how the speedometer cable disconnects from the drive on the front axle? 98 FLHTCUI. Ronnies shows it as separate part. Thanks. Ken
Old Nov 20, 2019 | 12:48 PM
RDHIGH's Avatar
RDHIGH
Yea- on my 92 you disconnect at the speedo - then just turn the whole cable counterclockwise to unscrew from the axle assy. If its too tight - put pliers or vice grip on the metal part of the cable at the axle and unscrew.
Old Nov 20, 2019 | 12:56 PM
EVOrider's Avatar
EVOrider
Same way my 1998 Ultra was before I converted to electronic speedometer.
evotrike's Avatar
evotrike
Thanks, RD! Sure beats taking the drive off. Ken
Old Nov 20, 2019 | 01:14 PM
RDHIGH's Avatar
RDHIGH
No problem- take care!
Old Nov 20, 2019 | 05:36 PM
evotrike's Avatar
evotrike
Figured it out. After checking pretty much everything related to the problem, finally laid down looking closely at the drive unit.
The 90 degree tang that hooks into the hole on the rotor had sheared off. There was enough material left on the vertical piece to drive down into the hole with a 1/8" nailset. We'll see how long it lasts, I hope as long as the original did.
Went out on me heading home from a 300 mile rt ride to the Talamina Byway in OK, somewhere in ARK. 75 *, great riding. Ken
Old Nov 20, 2019 | 05:44 PM
grbrown's Avatar
grbrown
Wink
As an aside I found that a tv aerial cable rubber boot is a good fit, to weather-proof where the outer and drive join. My first drive unit seized solid due to corrosion inside.
Old Nov 20, 2019 | 06:56 PM
Yankee Dog's Avatar
Yankee Dog
A straight spark plug wire boot works well also...YD
Old Nov 20, 2019 | 08:47 PM
evotrike's Avatar
evotrike
The boot appears to still be in good shape after all these years, remarkably.
Old Nov 21, 2019 | 04:52 PM
Hey Man's Avatar
Hey Man
There should be a teeny, tiny slotted screw near the bottom of the tube that the cable goes into. Not easy to find but it's there. Remove it and the cable will come out. If you don't you'll ruin the cable housing and possibly the the drive ripping things apart.
HD4EVR
EVO
Feb 16, 2014 09:27 PM
RidemyEVO
Jun 21, 2010 11:08 PM
Racer_Rick
Feb 1, 2008 05:02 PM
jgcable
Oct 9, 2007 08:12 PM
joinemar
Jul 24, 2005 07:28 PM
