Basket
Old Jan 15, 2020 | 12:55 PM
evotrike's Avatar
evotrike
Originally Posted by splattttttt
Is the noise noticeable only at stops? Or also when you’re moving?
And if its only noticeable at stops? Do you hear the noise both with the clutch cable pulled? Or even in nuetral?
The old noise (loud) was there all the time, in gear or not, clutch in or out. The chain had loosened up since my last check, about 1"+, not enough to mark the case, but noisy and clattery.
Put it all back together and set at 1/2-5/8" slack, and now chain noise is smooth and quiet with no other noise. Bearings all ok, thank goodness. Ken
Old Jan 15, 2020 | 01:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
IIRC 1/2-5/8" is for a hot chain and 5/8-3/4" is for a cold chain.
Old Jan 15, 2020 | 03:29 PM
evotrike's Avatar
evotrike
One notch down, too loose. One notch up, too tight. Ken
Old Jan 15, 2020 | 04:24 PM
texashillcountry
Dirt don't hurt
I agree with that completely but like I said the amount of slack you're supposed to have depends on wither the chain is hot or cold.
sB43
EVO
16
Nov 12, 2018 03:33 AM
SummitRK
Jul 7, 2016 10:06 AM
blair
Jun 25, 2012 05:24 PM
billyfish
EVO
Sep 4, 2010 04:02 PM
mbracey
Aug 10, 2006 11:31 AM
