98 wide glide
Old Sep 11, 2020 | 08:45 PM
LSTORY's Avatar
LSTORY
Default 98 wide glide
hey guys , i just bought a 98 wide glide . one of the 95th Anniversary ones . its kind of beat up , but seems to run good . has a gas leak at the petcock.. when i got home i noticed the drive belt seemed a bit thin . it measures 1 1/8 inch . the book says it should be 1 1/2 . is his some thing i should be worried about ?
Old Sep 11, 2020 | 10:01 PM
evotrike's Avatar
evotrike
. If the book says 1 1/2", then it needs a 1 1/2"....unless the pulley was downsized for some reason.
Old Sep 11, 2020 | 10:10 PM
Yankee Dog's Avatar
Yankee Dog
Rear pulley should match belt width.
As far as strength, no problem, but again rear pulley width should match.
If it don’t match, look at the bright side, the rear pulley is easily replaced. Front pulley...not so much. YD
Old Sep 11, 2020 | 10:39 PM
Beemervet's Avatar
Beemervet
Congrats. I'm partial to '98s myself. Deal with the gas leak before you do anything else, including starting.
Oh, THC wants to know where the pics are.
Old Sep 12, 2020 | 05:36 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Sounds like somebody might have went to a wider rear tire, to a 150 possibly.. The 1 1/8" belt was used on the 2000 up bikes.. It allows more room for a wider tire. As for strength? As said yes, no problems.... I got 115 lbs of torque going to my 1 1/8" belt.. I also wouldn't be surprised if somebody went to a 70 tooth on that rear pulley...
Old Sep 12, 2020 | 08:21 AM
Racepres's Avatar
Racepres
I would say, New Petcock and Screen... But, No Pics, so can't know there even Is a Petcock...
Old Sep 12, 2020 | 11:10 AM
EVOrider's Avatar
EVOrider
Thats what I was thinking.....upgraded swingarm for wider tire.
Old Sep 12, 2020 | 01:26 PM
LSTORY's Avatar
LSTORY
Default Pics
Petcock is a vacuum.
Old Sep 12, 2020 | 01:27 PM
LSTORY's Avatar
LSTORY
Default Belt
Old Sep 12, 2020 | 01:31 PM
LSTORY's Avatar
LSTORY
Default 521,125
Its a 4fter.1117/1998.
