Cutting out while cruising, backfiring, then die!
Old Oct 7, 2020 | 01:29 PM
Bass Player's Avatar
Bass Player
Hit n run, he gone.
Old Oct 7, 2020 | 09:33 PM
flhsport's Avatar
flhsport
It would totally die and gauge would go to zero. No electrical at all. Local indy found battery had good voltage but when loaded it totally died. Replaced battery and no more problem at least on a 75 mile test run. Old EVO circuit breaker in nose checked fine and no shorted or pinched grounds. Weird battery showed good voltage but none when loaded. Got warranty on battery thank goodness. No work done recently just happened out of the blue.
Old Oct 8, 2020 | 08:27 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Thanks for the update.
Old Oct 8, 2020 | 10:05 AM
Racepres's Avatar
Racepres
An extremely Common battery failure Mode...
thanks for the update..
Edit; Most commonly occurs with Yuasa battery that says "made in Taiwan" right on it.....
jgwoz62
Jun 25, 2018 07:35 PM
tmilo1000
Nov 4, 2016 02:07 PM
Hrlyric
Aug 2, 2013 05:21 PM
kaathrin
Electrical/Lighting/Alarm
Jun 13, 2009 02:47 AM
chefbayliss
May 20, 2008 02:05 PM
