Oil Viscosity and Evo's...
Old Feb 1, 2022 | 02:22 PM
  #31
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Ingramite
What?
Nobody uses Lucas Oil Treatment in their EVO?
I really did not see that mentioned anywhere in this thread.. but what oil filter do you use... Lol...
Old Feb 1, 2022 | 03:46 PM
  #32
mike131's Avatar
mike131
Id have to look in my service manual, but doesn't it say something like "up to" 60 weight in hotter climates? but not a have to
Old Feb 1, 2022 | 09:36 PM
  #33
OLD 96's Avatar
OLD 96
Wow. I can't believe. The first ever oil thread on the forum. Just being sarcastic. I use V-Twin specific 20-50 in my Evo and Twinkie. Straight 60 wt. may make the lifters quieter in the Evo. I have run it. A trade off. In my humble opinion. Either one does the job that it is supposed to do. Although I am not a oil expert. But. I did stay at a Holiday Inn Express last night.
Old Feb 1, 2022 | 09:45 PM
  #34
Ingramite's Avatar
Ingramite
I use the chrome one.
I put a handful of magnets all over the outside of the filter too.
Most folks would tell ya that this old trick will trap metal shavings against the inside of the filter wall.
That's just an old wives tale.
The real reason for the magnets is to align the molecules of oil.
As in "opposites attract and likes repel."
Properly aligned by the magnets oil will properly lube and repel heat build up.
This is an old bikers trick I learned from a J.C. Whitney catalogue back in the 60's
Old Feb 1, 2022 | 09:57 PM
  #35
OLD 96's Avatar
OLD 96
Thinking about it a little more. With pans and shovels straight 60 wt. or 70 wt. oil was necessary with the iron cylinders and aluminum heads. With the Evo with aluminum cylinders with cast in steel sleeves with aluminum heads tolerances are much closer. So. V-Twin 20-50 Syn on the Evo. Just my
Old Feb 2, 2022 | 07:29 PM
  #36
Hey Man's Avatar
Hey Man
Originally Posted by ChopperBill
I always use 25-60 non synthetic.
I like that when I can get it but can't always find it out my way.
mchertel
Feb 2, 2022 08:40 AM
jbgoodner2
Nov 29, 2013 12:59 PM
INMIhog
Jul 1, 2012 09:39 PM
niteowl02
Sep 13, 2008 09:53 AM
anubisss
Dec 4, 2006 10:56 PM
