Ultima 107" motor on a 90 model Bagger
Old Mar 17, 2009 | 09:17 AM
  #491
paco's Avatar
paco
hey John,
there is a white wire on a carbed bike, but on the efi there isn't. the coil wire is routed thru the ecm-efi-etc and it ends up a gr/yel. Will sent me the wire diag and i found the wire to the fuel pump which i am not going to use. it should be hot when the run switch is on and off when the switch is off. I am going to splice it and check it for voltage. Just got to trace out the pink wire and i will have my tach.
Will, have you found out if the cruise will work w/o the ecm ?
later.........
Old Mar 17, 2009 | 05:15 PM
  #492
wmattert's Avatar
wmattert
Paco, I left the ECM in. I just splice into the wires i needed and removed all the stuff I didn't.
Old Mar 21, 2009 | 08:43 AM
  #493
TheGoat's Avatar
TheGoat
Paco,
Nice work on that project of yours. Great pictures.
Ordered D&D Fatcat 2 into 1 and Ultima 6 speed tranny. Will be hitting the road with it today for a test run. Thing sounds awesome with the Fatcat.
wmattert,
Bike is looking good and thanks for the pics!!
Have a good weekend,
Old Mar 22, 2009 | 04:28 AM
  #494
TheGoat's Avatar
TheGoat
Bike goes good with the new pipe. Good pull down low and the tranny is smooth. Here are a couple of updated pics.
Old Mar 22, 2009 | 07:39 AM
  #495
wmattert's Avatar
wmattert
Looks nice Goat!
Old Mar 22, 2009 | 08:42 AM
  #496
TheGoat's Avatar
TheGoat
Thanks wmattert!!
Old Mar 22, 2009 | 10:47 AM
  #497
miacycles's Avatar
miacycles
Goat,
the Ultima six speeds do shift sweet. Just remember to use a good gear lube(we use Royal purple heavy weight) and do not adjust the rear belt too tight!!!
Old Mar 22, 2009 | 11:16 AM
  #498
TheGoat's Avatar
TheGoat
Thanks John. Very much appreciated.
Old Mar 22, 2009 | 07:33 PM
  #499
paco's Avatar
paco
Got her looking goooood there Goat ! Glad all worked out for you. with that 6 sp you could ride down Alabama one weekend ...........
Will, have you got yours running ?
later.................
later...
Old Mar 22, 2009 | 08:32 PM
  #500
wmattert's Avatar
wmattert
No, the oil spout needed two spacers (baker spacer) and they are on back order everywhere but eBay. Waiting for the spacer. Damn luck...
