Bad lifter?
Old May 26, 2025 | 11:38 AM
Robtattoo's Avatar
Robtattoo
Have a listen at a crap video.....
It's 100% the front cylinder. I pulled the rods back out this morning & switched the inlet & exhaust side, just to see but it made no appreciable difference. I've got a top end gasket set ordered.
File Type: mp4
Old May 26, 2025 | 02:41 PM
t150vej's Avatar
t150vej
You don't need to take it all apart. Lay the front rod out and take the plugs out. Lay a rag over the tappet guide but not in the hole. Turn the engine over for 15 seconds. Wait 2 minutes then give it another15 seconds. Maybe one more time. The lifter should have oil laying in the top of it but wait a few more minutes to let out any bubbles. Put it all back together.
Feulings are a sob to bleed out and that's when I started doing that with any new lifter.
Old May 26, 2025 | 03:43 PM
Robtattoo's Avatar
Robtattoo
Thanks for the tip! I did it & it's pumped up just fine.
I checked the screen, also fine.
Reset the front rods & fired her up. Quiet as a new engine, until the rocker covers get hot, then taptaptaptaptaptap......
HOWEVER......
I slipped, while I was listening to the top end, via a 12" ź drive extension & hit the front exhaust pushrod tube & there was instant silence. Take pressure off the tube, tappity-tap-tap. Push the middle of the tube towards the cylinder: silence. Release pressure & you know the noise.
The sumbitch pushrod is somehow impacting the TOP of the inner pushrod tube.
Now, I have no idea what to do about that at all! Just replace the tube? Rod & tube? Buy a twincam? (I kid! 🤮 )
Old May 26, 2025 | 03:49 PM
t150vej's Avatar
t150vej
Try turning the cover. May take both sets of fingers. All else fails, find a 7/8" tapered hand reamer ream the top of tube and file smooth the end so you don't it won't cut the o-ring.
Old May 26, 2025 | 06:21 PM
Schex's Avatar
Schex
Carbide bur bit and a die grinder, open the top of the tube some.
Old May 26, 2025 | 06:40 PM
johnjzjz's Avatar
johnjzjz
We never had an issue with evo lifter pumping up - but the click 90 percent of the time its the lifter roller
sorry if someone else has said that already but that is usually the cause - i did read you went over the adjustment and as soon as the oil started to warm it came back-
Old May 26, 2025 | 07:00 PM
Robtattoo's Avatar
Robtattoo
That was my initial thought & I replaced the 25,000 mile lifters with brand new. However the tick persists & is definitely at the top end of the pushrod.
I've got new inner tubes on their way. Better safe than sorry, for $35
Old May 31, 2025 | 06:41 PM
Robtattoo's Avatar
Robtattoo
New pushrod inner tube fixed it!
i just ran a quick 90 mile circuit & the engine is a quiet as a new one! 😃
Funny how it's the little things that getcha......
Old May 31, 2025 | 07:08 PM
johnjzjz's Avatar
johnjzjz
You can feel its not right when rotated we just cut some off was not thinking the tube being too long we usually find the longest one is front exhaust
Little Mike
Engine Mechanical Topics
17
Dec 3, 2016 08:29 PM
mikebehr00
Exhaust System Topics
Aug 10, 2012 01:35 PM
96roadking
EVO
13
May 22, 2010 12:14 PM
swwilson77
Aug 20, 2008 12:27 AM
murf1
EVO
14
Apr 7, 2008 07:24 PM
